1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Blend door replacment
Old 01-19-2011, 07:05 PM
cleaningbug94's Avatar
cleaningbug94
cleaningbug94 is offline
I have the much hated heater problem where ac works great but heat in front works terrible. I know to that i am going to have to pull the whole dash to fix this. I was actually thinking about selling it but its just so nice and so much fun. Can someone give me direction about how to go about replacing this.
Old 01-19-2011, 07:44 PM
madsonp's Avatar
madsonp
madsonp is offline
There are other options to pulling the dash such as this: Auto replacement part, blend door fix, Heat, AC replacement parts If you do decide to pull the dash depending on the year of you vehicle I have some pretty good instructions. PM me with your e-mail address if you'd like to have them and I'll send them to you.
Old 01-20-2011, 10:16 AM
EddieBauer02's Avatar
EddieBauer02
EddieBauer02 is offline
I think I may give this a shot..sure would be a nice alternative to "Shop".
Old 01-20-2011, 06:31 PM
madsonp's Avatar
madsonp
madsonp is offline
A lot cheaper too.
Old 01-21-2011, 11:13 PM
NemesisNJ's Avatar
NemesisNJ
NemesisNJ is offline
I have a slightly diff problem, recently while driving, I wanted to leave the heat on low, but the speed setting for low, for heat or AC doesn't work. All other speeds are fine. Would this be a similar issue, or does the cluster for heating/cooling need to be replaced? As well the light for that cluster also have gone out, as well for the rear air control, both upfront. The backseat rear air control works fine and is illuminated.
Old 01-22-2011, 10:17 AM
hodges710's Avatar
hodges710
hodges710 is offline
The dash does not have to be taken out these days. Heater treater is awesome for showing you how to take the broken blend door out and putting it(NEW ONE) back in.
Old 01-22-2011, 10:46 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
There have been some posts about using a dremel tool to open the plenum enough to get your hand inside to do the replacement but there are some other posts showing the use of a Knife blade soldering tip on a soldering gun to make a smaller and neater cut which would help when putting the panel back into the plenum. I would use the Knife blade technique as it would likely make a neater job and not look like a hack job when it's finished.
Old 01-23-2011, 12:13 PM
c_hohensee's Avatar
c_hohensee
c_hohensee is offline
Do you have the manual hvac or the auto? If it is the manual it is likely that resistor pack for controlling the fan speed is going bad. I believe that is located on the plenum on the passenger side. The lights out could be bad bulbs that are replaceable.
aerohead34
06-07-2012 08:04 AM
Jake Higginbotham
1997 - 2003 F150
11-14-2010 07:20 AM
CharlieLed
03-09-2009 04:54 PM
jdcisonfire
1978 - 1996 Big Bronco
01-17-2002 04:00 PM
Quick Reply: Blend door replacment
