1978 - 1996 Big Bronco
Valve Covers
Old Jan 16, 2002 | 05:25 PM
jdcisonfire's Avatar
jdcisonfire
Post Valve Covers
Hey, I have a leaky valve cover, and I believe I need to replace the gasket...can anyone give me some advice on how to go about doing this:tools, specifics, etc. Your help is much appreciated!
Jake!
Old Jan 16, 2002 | 05:44 PM
chulsey12's Avatar
chulsey12
Valve Covers
[updated:LAST EDITED ON 16-Jan-02 AT 06:46 PM (EST)]i have a 90 bronco with a 351 and did the same thing last weekend, all you need is a 9/16 7/16 and 1/2 inch socket and some extensions, other than that no special tools needed, the only suggestion i can make is when you put the new gaskets on be sure to put some high temp permatex (black stuff in a small can) on the valve cover, then put the gasket on and let it dry to the valve cover for about 15 minutes and then leave the other side of the gasket dry and put it on be sure to double check the tightness of your bolts or else you will be doing the job twice, i promise you. i hope this info helps, if you need anything else let me know.
p.s. be sure to let the gasket dry to the valve cover, if you dont when you tighten the bolts the gasket will slide inside the valve cover and when you pour the new oil in it will pour out between the gasket and the head good luck
Old Jan 16, 2002 | 07:26 PM
Mil1ion's Avatar
Mil1ion
Valve Covers
There are TWO types of Gaskets.
Cork & Neoprene .
I prefer the Cork.
I usually soak the cork gasket in hot water for 1/2 hour before installing.
Copper Gasket sealer on the valve cover side.
*NOTE
Important to remember: When Torquing down on Valve cover Bolts,
Be VERY careful not to OVER-TIGHTEN them as they will crush the gasket,split it open and you will still have a leak.
This also goes for neoprene gaskets.
Don't over torque them.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 17, 2002 | 04:00 PM
DeGideo's Avatar
DeGideo
Valve Covers
Resendiz
Oct 18, 2016 08:56 PM
FREDDAY
May 20, 2016 05:15 PM
twigs
Jul 16, 2015 01:54 PM
Mustangking1
Jan 19, 2014 09:12 AM
FitchBanjos
Apr 5, 2008 11:20 AM
