03 6.0 no crank
Thanks.
So, did the truck crank with the old fan clutch unplugged!?
Or did it crank only after you plugged the new clutch!?
I unplugged the fan clutch and still no crank!
Thanks.
the issue with the failed clutch is that it shorts and pulls down a voltage supply. unplugging it allows the voltage supply to stay in the acceptable range for everything to function.
unplugging it should have allowed you to start the truck. unfortunately the clutch is not your issue.
I intend to diagnose the issue further with an AutoEnginuity tool.
A third possibility is the ICP sensor but reaching that thing is extremely difficult for me at this time.
i learned from searching when i had my problem, that the range selector has a sweeping voltage rather than different switches, making it harder to figure out. someone had posted the voltage readings somewhere in 6.0 section, so you can tryto diag that angle with a volt meter.
if you think its the ICP sensor, i would assume its cranking and not starting? if it were the fan clutch or shifter position it would not crank at all.
The fan clutch is on the same circuit as the transmission range sensor. A short in the fan clutch/wiring can cause a no-start because of the affect on the transmission range sensor (IIRC).
Also, if someone cant get the starter to crank when jumpering the starter with the "yellow wire", then they are looking in the wrong places when looking at the fan clutch or range sensor (or at least those would be secondary issues).
Can you tell me where exactly to measure the voltage of the range selector?
And no it is not cranking.
Thanks for the continued support.
HERE Is what Voltage my SGII reads for Tranny Range
It worked these are the values I came up with when I moved the gear selector
transmission range sensor values
park=140
reverse=120
neutral=100
drive=92 and remained the same threwout the driving range 12356
3rd= 46
2nd=44
1st=42
IDK Honestly if this is what you would get with a DVM IMO the Numbers should Have Fallen into the 5Volt V-Ref so Im thinking a Decimal Point
So Like PARK=1.40volt
But with SGII it dont Matter It Just need a Diffrent Value For Each Range
PCM will only engauge starter in Park oe Nuetral
Are you with ME??????^^^^^
park=140
reverse=120
neutral=100
3rd= 46
2nd=44
1st=42
JPMallory
27
06-09-2017 01:01 PM
blue66f100
06-08-2002 06:52 PM
