Crank times
Old Oct 7, 2015 | 12:45 PM
bizzelj's Avatar
bizzelj
Crank times
Hey guys just got out to my truck after work. Cranked up this morning fine ran fine all the way to work set about 8 hours come out here tried to crank for about ten seconds didn't crank. Turned key off cranked right up. Where do I begins diagnosing this?
Old Oct 7, 2015 | 01:02 PM
navistarnut's Avatar
navistarnut
Do you have scanguage or something to show FICM voltages?
ICP needs 500 just to start
System voltage? Check obvious like battery connections, three plugs on back of FICM.
Is there injector buzz KOEO before you crank?
Do you hear the HFCM running KOEO?
Would help to know what year truck is.
Old Oct 7, 2015 | 03:35 PM
bizzelj's Avatar
bizzelj
Sorry it is a 2005 f250 114000 miles. Yes I have a live wire ts I am leaning towards week battery it builds 800-900 psi when cranking but the battery colts are low
Old Oct 7, 2015 | 03:40 PM
navistarnut
When you say the voltage is low, how low?
Low volts are hard on the FICM during cranking. Might want to load test both batteries as well
Old Oct 7, 2015 | 03:55 PM
bizzelj's Avatar
bizzelj
Around 10 and when driving lower 13s and if I read correctly they should be around 13.6 at the lowest when engine on
Old Oct 7, 2015 | 04:09 PM
bizzelj's Avatar
bizzelj
Found some corrision as well
Old Oct 7, 2015 | 04:42 PM
bizzelj's Avatar
bizzelj
Dropped to 8 wile cranking
Old Oct 7, 2015 | 08:30 PM
WatsonR's Avatar
WatsonR
thats really bad... it will kill the FICM
Old Oct 8, 2015 | 04:28 AM
bizzelj's Avatar
bizzelj
Replaced with two optima batteries last night only problem is the stock brackets won't fit and the cables were barely long enough
Old Oct 8, 2015 | 07:05 AM
bizzelj's Avatar
bizzelj
Let me rephrase the optima batteries won't fit the brackets. Hit a dang bump this morning and the truck cut off. So now I need to figure out a way to secure thes new batteries and get new ground cable and possible a new red cable for the passenger side. So the truck cut off and cut back on then I was stuck in 3rd gear it would only downshift pulled over cm checked my connection started back and ran fine. The transmission messsed up because of the battery connection or is this another issue?
Old Oct 8, 2015 | 09:44 AM
jswartz84's Avatar
jswartz84
I would get the correct batteries for the truck. I used to think Optima was a great brand, after 4 failed Optimas in 4 years (2 different cars) I will never buy another one again. If you set on a more expensive battery, look at the AGM batteries.
Old Oct 8, 2015 | 09:58 AM
bizzelj's Avatar
bizzelj
They do have a warranty so I think I will keep them for now at least unless I can't find a way to keep them secured. Do you think my transmission is ok? After it cut back on it got stuck would only downshift but after I turned it off and back on it worked just fine
Old Oct 8, 2015 | 10:20 AM
jswartz84's Avatar
jswartz84
Yeah mine were under warranty as well, still cost to replace them.
Maybe look for places to hook a ratchet strap and secure it down. If you are creative, you can build new bolt down blocks to replace the factory battery hold downs.
I doubt you tranny is messed up, but try to get the issue corrected before anything worse happens.
Old Oct 8, 2015 | 10:28 AM
WatsonR's Avatar
WatsonR
Optima's are horrible. Get an Advance Auto AGM. Use code TRT30 for a 30% discount ($50) and buy on line, do in store pick up and save the apsrin for another day.
Old Oct 8, 2015 | 11:00 AM
Mikenski's Avatar
Mikenski
I had same issue, I had 2 yellow top optima batteries, went to mech and did load test both were dead within 3yrs, got 2 interstate Mega tron plus batteries, and they have a 6yr warranty, truck starts right up and batt levels are at 14v +
