C6 length question
C6 length question
I acquired a C6 out of a 68 LTD and I'm wondering if the tailshaft is the correct length. I want to put it in the 74 F250 I have to change it back to the auto it used to be...currently has a 4 speed but the column is still auto. My truck is 4wd. The tail housing measures 15 inches. Is a car C6 the same as a 2wd truck? I'm assuming I would need a 2wd trans since my t case is divorced.
Thanks
Thanks
some are some aren't depends on car...most truck c-6s have a mounted flange while the 2wds use a slip yoke...its still doable so long as you don't mind refabing the intermediate driveline...I've done it on a couple other trucks cause the truck trans are so hard to find...2 things to check, total lenght of trans v/clearence between rear of trans and t-case and trans mount location due to some cars mounts being further back.///.
Myfreeford
05-30-2012 09:09 PM
poorfolks
08-17-2004 09:24 AM
