How much can a f60 tow?
the main problem with what you will be towing would be the braking ! if the trailer brakes quit working and you have the dump loaded with dirt it wont stop worth a hoot ! with 3 axles ( 6 brakes ) a lot more potential for brake problems , we always liked a 2 axle trailer
ether with duals or with single with 215x17.5 tires and wheels ( axles were 8-10,000 # ).
if you use electric brakes dont go cheap on the controller !
we had C-60 with 350 and 4 spd , f-600s with 330 , 361 , 300 gas burners and all pulled ok , no speed records ! if you put that 8.3 in one it should pull a mountain down !
thanks for the reply's
What I ment to ask is what is the legal weight I can tow. right now i have a 2004 f450, and pull a 24 foot three axle gooseneck trailer with 7000 lb axle and brake on all three. I run into probelms when I tow my over built 20 foot dump trailer that has tandem duals with a henderson supension and 19.5 tires (just under 9000 lbs) I load 14000 lbs of rock or dirt and I,m wieghting in at 36,000 why over my CGVW. So my question is: is there a CGVW rating on these trucks? I haven't figured out if I'm going to take the dump bed off and put a flat bed on it and use my trailers the way they are or sell the dump trailer and mod the three axle to a pintle hitch.
thanks doug
just need a bigger truck
thanks doug
f600 are good for 26000 lbs legally. You need a 700. Or join the big boy club and get a class 8.. Need a CDL though, atleast here in washington..
Your way over on the 450.. I guess most people that haul around small excavators with pickups probably are overweight. Good thing the police havent caught onto that.
Shenna Tipton
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-22-2015 12:19 AM
DLG
07-03-2006 01:29 PM
