Sponsored by: Real Truck
Flat tow?
Old Mar 16, 2016 | 10:14 PM
Coolhand5599's Avatar
Coolhand5599
Flat tow?
Can you flat tow a 2016 F350 4x4?
Old Mar 17, 2016 | 05:07 AM
senix's Avatar
senix
Only if it has a manual 4x4 system so that the trans will be completely isolated from the running gears that will turning as you tow.
Otherwise you would have to disconnect the drive shaft.
Or trailer the truck.
Old Mar 17, 2016 | 06:54 AM
wrvond's Avatar
wrvond
Towing the Vehicle on Four Wheels
Emergency Towing
If your vehicle becomes inoperable (without access to wheel dollies, car-hauling trailer, or flatbed transport vehicle), it can be flat-towed (all wheels on the ground, regardless of the powertrain and transmission configuration) under the following conditions:
  • Your vehicle is facing forward for towing in a forward direction.
  • Place the transmission in position N. If you cannot move the transmission into N, you may need to override it. See Automatic Transmission.
  • Maximum speed is 56 km/h.
  • Maximum distance is 80 km.
WARNING
If your vehicle has a steering wheel lock make sure the ignition is in the accessory or on position when being towed.
Recreational Towing
Note: Put your climate control system in recirculated air mode to prevent exhaust fumes from entering your vehicle. See Manual Climate Control.
Follow these guidelines if you have a need for recreational towing, such as towing your vehicle behind a motorhome. We designed these guidelines to prevent damage to your transmission.
Two-wheel Drive Vehicles and Four-wheel Drive Vehicles Equipped with an Electronic-shift Transfer Case
Do not tow your vehicle with any wheels on the ground, as vehicle or transmission damage may occur. It is recommended to tow your vehicle with all four (4) wheels off the ground, such as when using a car-hauling trailer. Otherwise, you cannot tow your vehicle.
Four-wheel Drive Vehicles Equipped with a Manual-shift Transfer Case
  1. Put the transmission in position N.
  1. Put the transfer case in position N.
  1. Put the hub locks in the FREE position. Always make sure that both hub locks are set to the same position.
Ken326
Nov 26, 2018 10:29 AM
rrthor
Oct 19, 2016 05:30 AM
et_miller_87
Jun 19, 2014 02:48 AM
v10kenj
2009 - 2014 F150
Oct 9, 2013 10:26 PM
2003V10F250
Modular V10 (6.8l)
Jun 23, 2005 12:51 PM
