Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
How much can a f60 tow?
Old 01-12-2011, 08:05 PM
79f350ds's Avatar
79f350ds
79f350ds is offline
Looking at buying a 1978 f600 4x4 dump truck. Going to put in a 8.3 cummins, but does anyone tow with one of these. Would like to tow a three axle trailer with a 545d tractor on it (about 13000 lbs).
doug
Old 01-12-2011, 11:06 PM
Marc S's Avatar
Marc S
Marc S is offline
Piece of cake. I have towed my mini excavator on a two axle trailer with my 1970 F600 that has a 345hp 428 in it. The towed weight is 14,000 lbs.
Old 01-13-2011, 10:09 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
No matter the weight make sure your truck can control and stop the weight.
Old 01-13-2011, 10:13 AM
cj06's Avatar
cj06
cj06 is offline
the main problem with what you will be towing would be the braking ! if the trailer brakes quit working and you have the dump loaded with dirt it wont stop worth a hoot ! with 3 axles ( 6 brakes ) a lot more potential for brake problems , we always liked a 2 axle trailer
ether with duals or with single with 215x17.5 tires and wheels ( axles were 8-10,000 # ).
if you use electric brakes dont go cheap on the controller !
we had C-60 with 350 and 4 spd , f-600s with 330 , 361 , 300 gas burners and all pulled ok , no speed records ! if you put that 8.3 in one it should pull a mountain down !
Old 01-18-2011, 08:38 PM
79f350ds's Avatar
79f350ds
79f350ds is offline
thanks for the reply's
What I ment to ask is what is the legal weight I can tow. right now i have a 2004 f450, and pull a 24 foot three axle gooseneck trailer with 7000 lb axle and brake on all three. I run into probelms when I tow my over built 20 foot dump trailer that has tandem duals with a henderson supension and 19.5 tires (just under 9000 lbs) I load 14000 lbs of rock or dirt and I,m wieghting in at 36,000 why over my CGVW. So my question is: is there a CGVW rating on these trucks? I haven't figured out if I'm going to take the dump bed off and put a flat bed on it and use my trailers the way they are or sell the dump trailer and mod the three axle to a pintle hitch.
thanks doug
just need a bigger truck
Old 01-18-2011, 10:21 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,682 Likes on 1,375 Posts
Old 01-25-2011, 03:40 AM
rummur s.c.'s Avatar
rummur s.c.
rummur s.c. is offline
f600 are good for 26000 lbs legally. You need a 700. Or join the big boy club and get a class 8.. Need a CDL though, atleast here in washington..
Your way over on the 450.. I guess most people that haul around small excavators with pickups probably are overweight. Good thing the police havent caught onto that.
Old 01-25-2011, 04:52 AM
big job's Avatar
big job
big job is offline
F6
I towed a IH TD9 dozer for years with a 1950 F6 3 axle trailer with electric
brakes. Would have been a lot better if It had a 390 in it, but it wasnt
invented yet lol.
Old 01-26-2011, 01:19 AM
Marc S's Avatar
Marc S
Marc S is offline
I was pulled over by a DOT cop in Washington when I was towing my mini Excavator with my F350 dually. My GCWR was 28,000. I have a Class A license so I was ok. However, the police are starting to ticket people that are not licensed.
Old 01-27-2011, 01:56 PM
Crete's Avatar
Crete
Crete is offline
Need a CDL though, atleast here in washington...
Need one either way.
Coolhand5599
1999 to 2016 Super Duty
03-17-2016 06:54 AM
Shenna Tipton
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-22-2015 12:19 AM
Supercab
1997 - 2003 F150
08-11-2012 08:22 AM
mackda600
08-20-2009 07:31 PM
DLG
07-03-2006 01:29 PM
Quick Reply: How much can a f60 tow?
