What transmission do I have. I saw the specs somewhere but not sure where
Transmission Codes
B — Four-speed manual, T199, F-Series (Mexico sold units only)
W — Five-speed manual, Dana ZF (M5HD-W), F-Series
E — Four-speed automatic overdrive (4R100), gasoline engines, F-Series/Excursion/F53 recreational
stripped chassis (motorhome)
9 — Four-speed automatic overdrive (4R100), diesel engine, F-Series/Excursion
6 — Six-speed manual, Dana ZF (M6HD-6), F-Series
Transmission Codes
You Rock AGAIN.. Thanks
If you have never had the tranny flushed, you should have that done. You can get it done, with or without a new filter. If you haven't had it done, you should get a new filter also. If you just drain the pan, I don't know how many quarts you will need, but it's not nearly all of the fluid.
Here's the straight up way to DIY. Kudos to Mark!
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Trulyvintage
1947 and Older Ford Trucks
05-20-2011 10:40 AM
