What transmission do I have. I saw the specs somewhere but not sure where
the sticker says E under TR.
its a 2000 F250 Super Duty V10 |
Transmission Codes B — Four-speed manual, T199, F-Series (Mexico sold units only) W — Five-speed manual, Dana ZF (M5HD-W), F-Series E — Four-speed automatic overdrive (4R100), gasoline engines, F-Series/Excursion/F53 recreational stripped chassis (motorhome) 9 — Four-speed automatic overdrive (4R100), diesel engine, F-Series/Excursion 6 — Six-speed manual, Dana ZF (M6HD-6), F-Series |
Originally Posted by brd7666
(Post 9809995)
Transmission Codes B — Four-speed manual, T199, F-Series (Mexico sold units only) W — Five-speed manual, Dana ZF (M5HD-W), F-Series E — Four-speed automatic overdrive (4R100), gasoline engines, F-Series/Excursion/F53 recreational stripped chassis (motorhome) 9 — Four-speed automatic overdrive (4R100), diesel engine, F-Series/Excursion 6 — Six-speed manual, Dana ZF (M6HD-6), F-Series You Rock AGAIN.. Thanks |
is there a good, better, or best filter and gasket for the 4R100
How many Qrts should I get for this beast.
If you have never had the tranny flushed, you should have that done. You can get it done, with or without a new filter. If you haven't had it done, you should get a new filter also. If you just drain the pan, I don't know how many quarts you will need, but it's not nearly all of the fluid.
https://img340.imageshack.us/img340/...rannyfluid.jpg https://img156.imageshack.us/img156/...annyfluid2.jpg |
Here's the straight up way to DIY. Kudos to Mark!
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles |
What about my 5-speed auto?
That method won't work on a TorqShift. The TorqShift has an internal thermostat the will keep 90% of the fluid inside the trans until it is over 170°F. It takes a heated flush machine to change all the fluid in a TorqShift.
