The shift selector arm is broke or a pin is loose? Not allowing me to turn the ignition. Sometimes I can move the lever and get the key to turn....how do I fix this issue?
l don't have a pic handy but look under the dash and wiggle the shifter, you'll probably notice a couple bolts loose up there. Have a light under with you
yeah mine did the same thing, guy didnt tell me that when i bought it and stopped at a gas station to find out it wouldnt start, finally got it by putting it in nuetral, there are two gold bolts under there that had backed out, they are torx-30
