better fuel millage?????
short answer.. Nope. (I have a 350 drw so I'm stuck in the same spot)
and even IF you add some tuner and pull the DPF.. you're going up 2-3mpg.. not 10..
see this topic
https://www.ford-trucks.com/forums/9...ml#post9246098
Sam
see this topic
Sam
I have a 08 F450 dwr (4.10 rears) 2nd owner, (ford premium care warranty) with 23K miles. I have a CM flat bed that is full of tools/100 gal. fuel tank, Air compressor ect. I bougth the truck two or three months ago.
I was getting 10.2 mpg hand calculated. I deleted the doc/dpf and got the SCT livewire tuner. Im currently testing the canned extreme tune. I have gone through 2 tanks now, and I am getting 15.2 mpg hand calculated. This is mixed 50/50 highway city driving. After testing the canned tune, I am planning on trying Erics custom tunes and see if I can get any additional mpg's. I would consider my driving style ultra conservative.
GODSDOZER
GODSDOZER
GODSDOZER
GODSDOZER
GODSDOZER
GODSDOZER
I get 12.5 in the 50/50, and 14.5 on the hiway empty..
stock. I am not a conservative driver, but not a race driver either
I would not pull the trailer with the extreme tune. but this is when I need the mileage.
Sam
My local dealer said they prefered not to deal with it, but would.. if the issue was away from the engine/trans/rear, then they would work it
(radiator is ok.. for example)
but if it was engine/trans rear related they would give me the opportunity to restore the truck to stock before making a decision.
the issue I have with all that is, I bought the truck for towing AWAY from home.. and if it fails away (90% of the time) then I am at the mercy of the dealer where its towed after the failure.
Sam
Sam
conrad kornell
07-21-2003 10:28 PM
