Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Get more power out of 5.9 cummins
Old 01-04-2011, 09:12 PM
brockkrak1's Avatar
brockkrak1
brockkrak1 is offline
Hey all,
I have a 1994 F-600 With the 5.9 cummins. Runs great. plenty of power, however more is always good to. any ideas for getting more power? Electronics, turbo housings? etc... thanks guys
Old 01-05-2011, 09:15 AM
fellro86's Avatar
fellro86
fellro86 is offline
Do you still have the old rotary VE pump, or the inline P-pump? (right at the time when they changed..) The VE has some adjustments you can make pretty easily, the P pump requires a bit more work, but can definitely be turned up... These are both mechanical pumps, so no electronics are going to help.
Old 01-05-2011, 02:27 PM
brockkrak1's Avatar
brockkrak1
forgive me before i ask, how can i tell the diffrence in the pumps?
Old 01-05-2011, 02:33 PM
fellro86's Avatar
fellro86
fellro86 is offline
The VE is a rotary style, the injection pipes are arranged circular around the pump, while the P pump is an inline pump, the injection lines come off the pump in a line.
Old 01-05-2011, 11:14 PM
nevrenufhp's Avatar
nevrenufhp
nevrenufhp is offline
Last I remember, they didnt use the VE in the Fords. In that case, sliding the fuel plate forward is going to give you a good 40hp jump. Take off the 4 bolts on top of the rear of the pump, pull the cover off, then loosen the 2 screws on the fuel plate, and slide it all the way forward. That's all there is to it. You could also hike up the rpm, but that really depends on what you're willing to do to it, and what you want out of it.
Old 01-06-2011, 09:34 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
All good info. you can also find a lot of info at Dodge Cummins Diesel Forum
Old 01-06-2011, 10:39 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Rep points for nevrenufhp
This is definitely a candidate for the tech folder.
Old 01-06-2011, 10:48 AM
nevrenufhp's Avatar
nevrenufhp
All that how-to stuff is in my signature. Plus, in more detail.
Old 01-06-2011, 12:32 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Nice write-up there, mind if I link directly to it in the Large Truck Tech folder?
Old 01-06-2011, 12:54 PM
nevrenufhp's Avatar
nevrenufhp
That's what it's there for....to help others/ reference material. I do it for a hobby, so there's no commercial push, except the goofy Google ads.
Xaker12
05-08-2016 09:28 AM
2002exPSD
Large Truck
09-22-2014 10:20 PM
401477534
02-12-2011 07:58 PM
gt40racing
36
11-06-2010 01:30 PM
DrkZide
Engine Swaps
07-01-2008 01:29 PM
Quick Reply: Get more power out of 5.9 cummins
