What am I missing
Yeah, it sure looks like mine did.
86wv - Are you asking because it's not running well? I went nuts trying to get mine running right then found a vacuum leak hidden on the vacuum tree. There's an ell shaped tube/port on the bottom of the vacuum tree you might not necessarily see from above.
Also, check the vacuum lines that run to the A/C heater controller.
X1Lightning
1999 to 2016 Super Duty
05-05-2013 08:05 PM
Muchacho
1978 - 1996 Big Bronco
11-30-2011 12:01 PM
