Sponsored by: Real Truck
what is missing here?
Old Nov 10, 2012 | 05:33 PM
jawmarq's Avatar
jawmarq
Hi guys, new to the site, just bough a 99 F250SD and have a quick question, whats going on here? I have a feeling this isn't factory hose routing and wonder if whats missing might end up being problematic.
Old Nov 10, 2012 | 05:42 PM
boj760's Avatar
boj760
What's missing here?
Looks like the AC was removed. Mine has what I think is a condenser and perhaps a compressor in the left hand area towards the firewall of your pic. I've only had my 99 F250SD V10 for about a month, but I agree you're missing components I have. Does the AC work?
Old Nov 10, 2012 | 05:48 PM
EXv10's Avatar
EXv10
AC be gone.
Old Nov 10, 2012 | 06:04 PM
jawmarq's Avatar
jawmarq
No, no a/c, I figured this truck came without it though, as there arent any a/c settings on the hvac panel.
Old Nov 10, 2012 | 09:12 PM
Bigpipes 35's Avatar
Bigpipes 35
And for some reason your heater hoses are cut and spliced back together
Old Nov 10, 2012 | 10:36 PM
SC_Hoaty's Avatar
SC_Hoaty
Go to this site Use your VIN number to get Ford Window Sticker and key in your VIN to get a copy of the window sticker to see if AC was original equipment on the vehicle. The dash controls could have been swapped after the AC was removed.
My used F250 came with what I thought was the factory 6CD changer. Turns out someone added it after the fact - even though it was a Ford unit. It came out of a year older vehicle based on the radio serial number. Who knows why some folks make the changes they do?
Old Nov 10, 2012 | 10:37 PM
EXv10's Avatar
EXv10
Does the heater work?
Old Nov 10, 2012 | 10:54 PM
jawmarq's Avatar
jawmarq
The heater hoses were cut and spliced in two places, once right after the quick connects to the core, and once about a foot away. The heat does work. The way the hoses are routed seems strange to me, like they could be much shorter and more direct to the core.
Old Nov 11, 2012 | 08:52 AM
96_F250_Deezal's Avatar
96_F250_Deezal
wonder if there is a limit on the year model, search by my VIN# and I get a 404 error.
Old Nov 11, 2012 | 08:54 AM
96_F250_Deezal
heater hoses were spliced in a similar way on my truck. maybe previous owner had a slide in camper and ran heat to it.
Old Nov 11, 2012 | 09:29 AM
SC_Hoaty's Avatar
SC_Hoaty
404 error sounds like web site problem.
I, too, cannot make it work this morning.
This one works, but does not give you the window sticker - it simply decodes the VIN - https://www.fleet.ford.com/maintenan...ls/default.asp
Wonder if the sticker site will be back in operation soon? I have a pdf of mine, so it did work at one time. Pretty sure that is the site I used to get it.
Old Nov 11, 2012 | 09:35 AM
SC_Hoaty's Avatar
SC_Hoaty
Here is another link that gets a number of options (like AC) but again, not the window sticker.
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, Mazda Truck, Mercedes VIN Decoder
Old Nov 11, 2012 | 04:16 PM
jawmarq's Avatar
jawmarq
I don't believe any camper was on the back, this was previously owned by a tree removal company, has a utility topper. Don't know why they would need heat anywhere else ...
Old Nov 11, 2012 | 04:17 PM
Kdr358's Avatar
Kdr358
Someone may have installed a heater core bypass at one time? I had a 00 F350 that had coolant lines spliced to a T where coolant would flow to a hydraulic fluid tank. Maybe they had something similar.
jawmarq's Avatar
jawmarq
It also has speakers, but a factory blank plate where a stereo would go, and no wire harness of any sort to go to a stereo from what I can tell. Except for the antenna plug?
