What am I missing
Old 01-04-2011, 07:23 AM
86 WV_F150's Avatar
86 WV_F150
86 WV_F150 is offline
What am I missing
Can you guys look at these photos and see what I'm misssing. I took off the air filter and I know its missing the smog pump, but is there anything else this engine is missing. Thanks.
Old 01-04-2011, 09:26 AM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
The quality of your photo is poor. That makes it very diff. to tell what is going on.
Old 01-04-2011, 10:55 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Better pictures will help, but I can see that the rubber line which should go from the carb vent to the charcoal cannister is missing or is disconnected. This can cause you to smell gasoline.
Old 01-04-2011, 09:22 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
That's a 1986?
Old 01-05-2011, 01:36 PM
1986F150six
BaronVonAutomatic,
Since you have not received a response to the question of, "That's a 1986?"... it does indeed look to be a computer controlled [a.k.a. feedback] system. They were like this from 1984-1986 and I think earlier in California.
Old 01-05-2011, 07:26 PM
BaronVonAutomatc
Yeah, it sure looks like mine did.
86wv - Are you asking because it's not running well? I went nuts trying to get mine running right then found a vacuum leak hidden on the vacuum tree. There's an ell shaped tube/port on the bottom of the vacuum tree you might not necessarily see from above.
Also, check the vacuum lines that run to the A/C heater controller.
X1Lightning
1999 to 2016 Super Duty
05-05-2013 08:05 PM
jawmarq
15
11-11-2012 04:50 PM
Muchacho
1978 - 1996 Big Bronco
11-30-2011 12:01 PM
jason586
1997-2006 Expedition & Navigator
06-21-2011 11:24 PM
kens crewcab
08-09-2005 10:07 PM
Quick Reply: What am I missing
