1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rattling passenger door
Old 01-04-2011, 12:06 AM
Cluney93's Avatar
Cluney93
Cluney93 is offline
My passenger door rattles bad when I go over bumps in the road and it's really getting to me. Anyone know how to fix? Thanks much and happy new year to all!
Old 01-04-2011, 03:33 AM
PsycoJuana's Avatar
PsycoJuana
PsycoJuana is offline
BUMPING
my 2002 doors R driving me NUTS!
Old 01-04-2011, 07:32 AM
Fishin76's Avatar
Fishin76
Fishin76 is offline
I have to SLAM the SC doors shut to keep them from rattling. One I do that, their quiet, otherwise they rattle and squeak.
Old 01-04-2011, 07:42 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
RCKYMTN-PSD is offline
Supercabs sure are noisier. Especially in the winter.
I would pull the door panels, and tighten all of the regulator and window channel bolts. Check inside and out of the door for anything else that possibly came loose. Door handle, latch etc. Simple job. I did find the lower 10mm regulator bolt loose on my previous truck.
Old 01-04-2011, 08:00 AM
Rick03F250's Avatar
Rick03F250
Rick03F250 is offline
I've noticed that during the winter months that cinders and road trash tends to hinder the bottom locking mech. on the sc rear doors. Therefore the door don't close as tight.
I personally tried to take the lock out and clean it up, but it still ends up doing it again.
Try to spray some good cleaner or lube into the latch and work it alot, this may help your prob.
If the back door don't latch all the way then the front door will rattle.
Old 01-04-2011, 10:13 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Give this a shot, may help you out (and props again to Epic for one of the many great vid's he's created).
https://www.ford-trucks.com/forums/9...mod-video.html
Old 01-05-2011, 07:03 AM
RCKYMTN-PSD
That is a good mod but you will have to slam the supercab doors even harder to close all the way
Old 01-05-2011, 08:59 AM
Fishin76's Avatar
Fishin76
Fishin76 is offline
exactly what I was thinking.....
Old 01-05-2011, 11:58 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
i did my sc doors about a month ago and love it. my doors rattle because the window glass bolts were loose on both front doors. my dads 2000 crew was the same way bolts were all loose a little blue thread lock and all is good now
Old 01-05-2011, 05:02 PM
mikesmayhem's Avatar
mikesmayhem
mikesmayhem is offline
I have tubing added inside the door seals where the door latches are. Tubing was added without removing the entire door seal. There is about an 8 inch piece of tubing put inside the door seal where the latches are. It provides just enough extra material to have the door shut tight and make the rattling go away. Sometimes now I need to rotate the tubing because it is a little squished on 2 sides but it really made a difference.
darmento
04-20-2016 07:03 PM
Jamessmith1
2015 - 2020 F150
03-29-2016 07:08 PM
supercrewser1751
2009 - 2014 F150
21
03-23-2016 06:46 PM
jhaas63
07-29-2014 08:37 AM
rokhedjo
01-11-2008 06:42 PM
Quick Reply: Rattling passenger door
