Upgrade steering on '76 F250 highboy
My power steering pump was making noise as long as I've had the truck, don't use it much... wood hauler... Anyway after I finally got around to replacing the pump it steers a lot better. All the play must have been in the valve from lack of of pressure and flow.
Also tightened the screw on the output shaft to get the play out of the gear...
Ive got a 78 250 ranger with powersteering thats really bad. I mean its like 4 or 5 inches of play at the wheel. I let the little lady drive her once and she almost crapped herself lol. Guess im used to it by now. When i turn the wheel with the truck off and parked the shaft going into the gearbox moves but none of the steering components after the box move. That means all my play is in a shoddy steering gearbox right? How hard/expensive is this to replace? Thanks guys!
I changed it to this ..
I run 31's x10.5 no problem .. Not even close to rubbing ...
Aside from that , you can put the box farther forward if need be .
Seriously..Maybe your a good welder and it will never break but if not done right by someone say without a good welding machine or skills to tackle the job it could be a disaster.I wouldnt even post a pic of your setup.
As a welder myself I know it could be done but there are MUCH better options...
To the original post if you want the best steering with no play i would suggest a 2wd box on the inside of the frame. I run mine with hydro assist and its awesome!! highway speeds/ 44" tires no problem it tracks straight
here read this on what i did...
https://www.ford-trucks.com/forums/1...teering-4.html
So pretty much dont reccomend this hack setup to anyone as it is Illegal and if done wrong will probaly kill someone!
its been in place for 20 years .I don't have an over inflated view of my self worth as you ...Sorry to hear you don't have faith in your self proclaimed expertise...
Maybe you should call the cops on my "illegible " set up ....
Ive got a 78 250 ranger with powersteering thats really bad. I mean its like 4 or 5 inches of play at the wheel. When i turn the wheel with the truck off and parked the shaft going into the gearbox moves but none of the steering components after the box move. That means all my play is in a shoddy steering gearbox right?
