Possible bent steering linkage?
Well yesterday evening on my way home from work a 1999 Mercedes pulled out in front me as I was doing about 50. I managed to swerve and only sideswipe them. They're gonna need front and rear door on drivers side replaced. My truck on the other hand only has a baseball size dent in the front right of the bumper and the right parking light is slightly cracked. However, the impact pushed my up into a median filled with snow and now my steering wheel sits about 1/8 of a turn to the right when moving strait. The wheels appear to track strait, but does anyone know what the possible causes would be? Bent tie rod maybe? Can an alignment just go out like that?
If that screw-type sleeve that's in the steering link is loose (not properly torqued), it could have jumped a few threads. We had a thread on here a while ago about these adjusters getting loose and creating problems. To locate the adjuster sleeve, see:
https://www.ford-trucks.com/forums/7...ml#post6807416
However, this is not the thread about properly torquing those bolts, which I can't find right now. The proper torque value for these bolts is 45 ft/lbs, however.
Pop
Pop
Thanks for all the replies! Pop, how do I verify the 1/16" toe in? I'm gonna head to the car wash in a bit to wash all that snow out of the bumper and other places it got to, then will check for any play in the parts. Will try the drag link adjust after I figure out the measurements. If the toe in is ok then does that more or less mean that nothing got bent? I knew our trucks were beasts!
64rednwhite
09-28-2016 12:14 PM
Roelito78
12-23-2009 07:39 PM
JAMAN1111
1999 to 2016 Super Duty
25
07-15-2009 07:52 PM
