96 302 Firing Order
Old 12-18-2010, 07:20 PM
Decoder01's Avatar
Decoder01
Decoder01 is offline
Question 96 302 Firing Order
Hey all I got a question for you all about the firing order on my 1996 302 EFI - So I have been working on my truck for the past few months and and fired her up this afternoon for the first time in a few months - had the motor out to replace the oil pan and a cracked manifold and did a "few" upgrades in the process.
Anyways It stated up but was skipping really bad so I shut it down and we startd to look at things and I noticed the firing order I used and the one on the sticker on the radiator support are different - so I switched the firing order to the one on the sticker and fired it back up and she ran beautiful - so I'm thinking the one on the radiator support is the correct firing order but I checked both the Chilton and Motorcraft service manual and they are different then the sticker on the radiator support so what gives?
Here are the firing orders from both books for a 1996 5.0 Vin "N" 302:
1-5-4-2-6-3-7-8
Now here is the one from the sticker (and works):
1-3-7-2-6-5-4-8
Looking up the firing order on the sticker it's for a 5.8L 351 so says Chilton and the Motorcraft book - any ideas why the sticker on the truck and the books are different and anyone else run into this?
And the truck has a 302 and the VIN is "N".
Thanks,
Dave
Old 12-18-2010, 07:54 PM
MariosF250's Avatar
MariosF250
MariosF250 is offline
Dont know why u have issues but at least you got it running. i dont understand how u have a 302 and w/ the incorrect firing order and it runs? what mods did u perform out of curiosity
Old 12-18-2010, 09:14 PM
CWPottenger's Avatar
CWPottenger
CWPottenger is offline
Firing order is controlled by the camshaft grind.... So if engine has a different camshaft, firing order can change, also different years had different firing orders...
just depends on mfg of cam and model of cam... There are different schools of thought as to which order is best for a Windsor family engine...
Old 12-18-2010, 09:45 PM
Conanski's Avatar
Conanski
Conanski is offline
All 302/5.0 motors built after 1994 use what is referred to as the 351/HO firing order... 13726548, and any publication that says otherwise is simply wrong.
Old 12-18-2010, 10:24 PM
Decoder01's Avatar
Decoder01
Conanski - Thanks that makes sense then and matches the factory sticker on the radiator support which is what I ultimatly used. Just wish the books would note that somewhere.
Marios thanks that is the picture I was referring to and as Conanski pointed out it all makes sense now. Using the book it skipped with the 302 regular firing order. But using the firing order from the factory sticker on the radiator support it runs like it should. Never thought to see if the two matched - who would have thunk...
Thanks again.
As far as mod's just bolt on stuff - msd coil, new wires, msd cap (stock distributor), JBA shorty headers, Magnaflow y-pipe with high flow cats, and a Gibson cat back exhaust. I think that's it for engine mods.
Old 12-19-2010, 12:53 AM
MariosF250's Avatar
MariosF250
sweet learned something new today
Old 01-22-2011, 12:37 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
So, for my 93 Bronco 302 the firing order should be 1-5-4-2-6-3-7-8, right? I checked and the only crossfire in this sequence could be in the 7-8 part.
Old 01-23-2011, 06:13 PM
Decoder01's Avatar
Decoder01
Sound right to me
Old 01-23-2011, 07:28 PM
BigBlue83's Avatar
BigBlue83
BigBlue83 is offline
So on the subject of firing orders, I would like to know how a 351 swap in a pre 96 302 truck would work. They would have different firing orders. You would obviously have to put the plug wires on in the 351 firing order but how would the computer handle it?
Old 01-23-2011, 07:35 PM
Conanski's Avatar
Conanski
Conanski is offline
With batch fired injectors the engine firing order doesn't matter.. all cylinders are covered in both cases and we know this because Ford wires the injectors the exact same way for both motors.
Old 01-23-2011, 07:36 PM
big-ugly's Avatar
big-ugly
big-ugly is offline
^^^ probably one of the many reasons why it is always advised to use the computer out of the donor.
Old 01-23-2011, 07:39 PM
big-ugly's Avatar
big-ugly
big-ugly is offline
Again I stand corrected, thank you conanski for your input. Learn somethin' new every day!
Old 01-23-2011, 07:43 PM
Decoder01's Avatar
Decoder01
Conanski - any idea why they changed it?
And why the books are wrong?
Old 01-23-2011, 08:51 PM
Conanski's Avatar
Conanski
Conanski is offline
What I have heard/read is the 351/HO firing order produces better harmonic balance. As for why the books are wrong.. who knows, most parts store don't have accurate info on these trucks either, but then Ford did make a lot of changes to many parts over the years.
Old 01-23-2011, 09:56 PM
BigBlue83's Avatar
BigBlue83
Thanks. Just so I am clear I have an 89 F150 with the 302 and about 256,000 so the old dawg is pretty tired. As long as the plug wires are on the correct cylinders the 351 will work, right. The other question I have is if the motor I found will work. It is a 96 model 351W complete from intake to oil pan. I was just wondering if it will work with my EEC-IV computer cause it is a roller motor.
saxtonj
02-12-2016 03:59 PM
55F250
09-09-2015 07:58 PM
rockittsled
1983 - 2012 Ranger & B-Series
02-07-2014 03:26 AM
Icansurf
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
03-27-2004 07:50 PM
bronco 1996 16 year old
1978 - 1996 Big Bronco
10-08-2003 07:31 PM
Quick Reply: 96 302 Firing Order
