I have a problem with the gravel pan hitting the front of the inner fender were the air deflecter bolts to it. The gravel pan won't bolt up on the ends.Maybe if i unbolt the fender braces then bolt the gravel pan i will get some play. Hope some one is seeing what i'm saying.
If I were you, I'd bolt the front clip together on the ground away from the truck and then put on the truck as an assembly, including the inner fenders.
Thanks but that ain't going to happen. I got every thing mounted to the inner fenders nice and neat. It took forever to get them front fender on . THANKS ANYWAY
If you bolt up the headlight panels, it will suck in the fenders, and put the inners in the correct position.
Thanks ALBUQ F-1 !!!!! Man you got to luv this site you got a problem and all you got to do is tell folks from all across the USA and CANADA and SHAZZAMMMMM you got a answer to your troubles.
