53 Gravel pan to radiator seal ????
OK, since the temps here have climbed above 95* my 53 has been running a little warmer than I like at highway speeds. I have had the radiator seals for some time, the one for the hood is no problem, but how do you install the one between the gravel pan and the radiator without disassembling the grille? I know it was originally stapled (what idiot came up with using staples in steel?), but how can I attach it?
Received 4,131 Likes
on
When I bought mine from Midfifty for my 56 I also purchased the SS screws that they mention that makes it easier to install. It's been awhile since I bought them and of course I haven't got to the point where I'll be installing it any time soon. At any rate I hope this is of some help.
John
John
on
I have an old gravel pan that was on my 56 panel, I can take a picture of it if that will help but in any case it was stapled to the flat section of the pan so it deflected the air towards the rad.
on
OK, I was able to get a small air drill between the radiator and grille to install the seal with self drilling screws.
I took the truck for a 100 mile run today, outside temps between 95 and 103*, and the seals did help somewhat. Where the truck would run temps of 210-220* before, it didn't even get up to 210* today. I still would like to see them lower though, I am hesitant to install the A/C until this is remedied.
chad77
05-31-2016 02:07 PM
Irelands child
Fifth Wheel & Gooseneck RV Towing
10-29-2015 11:21 AM
Walston
08-06-2015 07:13 PM
Gibby55
07-26-2014 04:15 PM
