1969 Crew 8 lug. Will like 1985 8 lugs rims work??
My father-in-law picked up a 1969 Ford crew cab 8 lug rims, 4 speed 390 2wd.
The truck has split rims, and 25 year old tires. I work at a tire shop and I have some 245/75/R16's for him. I would like him to find some 8 lug wheels that aren't split rims.
What factory 8 lug ford rims will work with this truck?
What years? A guy in my area has some 8 lug steels off a 1999? or do I have have to keep within a certain era like only up to 1985 or 1995.
Sorry know nothing about the older fords.
Yup, I have 84 rims on my 69 right now.
If the truck has factory disk brakes with the giant Dayton calipers, then you will have to be careful in wheel selection. Those calipers typically only fit under the 16.5" rims, but you may be able to find an aftermarket 16" wheel that will clear them.
I have had 16" splits before, but never 16.5. You also will never have a 16" tire on a 16.5 rim. The rim itself measures 16 and 1/2 inch diamter at the bead. If you were to try to put a 16" tire on a 16.5 rim, you will have dangerous and catastrophic results.
The old bias ply tires were generally marked 7.00 R16
The correct term is lock ring wheel, everyone calls these split rims though. Split rims were actually 20" wheels that joined together in the center (also known as suicide wheels). Split rims (technical term is the RH5 wheel) have been outlawed by OSHA,
lock ring wheels are still serviceable as long as the components match. There were no 16.5 inch lock ring wheels. Just thought you guys might want a little clarification.
Picked the set of basic 16'' steel wheels. They say ford all over them and measure 8X6.5".
They have the steel shorty valve stems I was told to keep them in because they are stronger and don't leak. Not sure though, I woudn't mind going to a new set of 2'' rubber valve stems.
So im going to have a set of 245/75/r16 toyo's that are 25 years old, and lock ring wheel's sitting here. Gonna throw them up on a local classified site for $100.00 Wonder if any old timer would want lock ring wheel's?
cbsales
49
12-06-2022 07:27 AM
sobz
02-08-2015 11:52 AM
calshamus
56
07-08-2011 09:41 AM
MADFord4X4
01-17-2011 01:18 AM
