4x4 problem
The truck doesnt go into 4wheel drive when i go from 2h to 4h and the light on the dash does not come on. When i start the truck the lights come on, on the dash so the bulb isnt burnt out. I dont hear the 4wheel drive kick in at all. No noises are made when i turn 4wd on. Hopefully that helps
From what others have posted, that sounds like the actuator motor on the transfer case is sticking/malfunctioning. Most try to unstick it by tapping on the actuator motor with something non-metalic, like a wooden hammer handle. A similar situation/procedure as when a starter solenoid is sticking... The motors are prone to siezing when not used regularly.
Yea definately replace the shift motor. Its going to stick again guaranteed. May take a while but it will. And the time it will stick is when your stuck. Not good haha.
Stinger10
05-20-2011 04:48 PM
