4x4 problem
Old Dec 11, 2010 | 05:09 PM
blueovalmann's Avatar
blueovalmann
4x4 problem
i have an 06 xlt with automatic hubs. I turn the **** to put it in 4wheel drive and nothing. I dont hear anything but when i start the truck the lights turn on on the dash please help
Old Dec 11, 2010 | 08:25 PM
danorules's Avatar
danorules
i don't understand what the problem is? we need more info
Old Dec 12, 2010 | 11:02 AM
blueovalmann
The truck doesnt go into 4wheel drive when i go from 2h to 4h and the light on the dash does not come on. When i start the truck the lights come on, on the dash so the bulb isnt burnt out. I dont hear the 4wheel drive kick in at all. No noises are made when i turn 4wd on. Hopefully that helps
Old Dec 12, 2010 | 11:29 AM
danorules's Avatar
danorules
give this a look. i think it will help.
https://www.ford-trucks.com/forums/8...then-some.html
Old Dec 12, 2010 | 02:59 PM
60DRB's Avatar
60DRB
From what others have posted, that sounds like the actuator motor on the transfer case is sticking/malfunctioning. Most try to unstick it by tapping on the actuator motor with something non-metalic, like a wooden hammer handle. A similar situation/procedure as when a starter solenoid is sticking... The motors are prone to siezing when not used regularly.
Old Dec 13, 2010 | 05:51 PM
blueovalmann
thank you so much i tapped on it and it started working everytime i turned it on. is there anything i have to do to keep this from happening again?
Old Dec 13, 2010 | 06:32 PM
fordman19762003's Avatar
fordman19762003
you might want to think about getting a new shift motor, once they get to the point that you have to tap them to get them to work they are usually one their way out.
Old Dec 13, 2010 | 07:20 PM
FordMstrTech's Avatar
FordMstrTech
Yea definately replace the shift motor. Its going to stick again guaranteed. May take a while but it will. And the time it will stick is when your stuck. Not good haha.
nybronc
Aug 12, 2013 01:06 PM
boa1558
Jul 7, 2012 09:20 AM
AggieOutlaw
Apr 5, 2012 03:31 PM
Stinger10
May 20, 2011 04:48 PM
truckalpers
1997 - 2003 F150
15
Jan 15, 2005 08:33 PM
