"check coolant additive" Warning
At 12700 miles this warning just came on my message center...I called one Ford dealer.."they had NO idea" I called another one and they said they would do research and get back to me...2 hrs later they called and said they ordered the additive (quarts only) they informed me that I would need to bring the truck in and they would test the antifreeze with "test strips" and they would determan if they additive was needed at that time (of course this is an extra charge)
It seems really early at 12k to have to start having this tested...
Anyone else having this issue???
It's normally going to be every 15,000 miles, but the PCM adjusts as necessary depending on operating conditions.
Lots more information here:
https://www.ford-trucks.com/forums/1...-additive.html
Do you have lots of idle time?
Originally Posted by diesel supplement
Every 15,000 milesInspect engine and secondary cooling
system concentration (freeze-point
protection), additive strength
(corrosion inhibitor), coolant level and
hoses
hoses
petro1
6.7L Power Stroke Diesel
08-24-2011 05:17 PM
MattL09
1999 to 2016 Super Duty
07-31-2010 11:54 AM
