my truck is leaking oil bad! i know for a fact the rear main is leaking. but it is also leaking from the front too and its not the crank seal. i already checked the HPOP reservoir and not that either. can anyone tell me some more places it can leak from?
Mine was leaking from one of the "Blank" plugs on the HP oil galley. I replaced it and put an HPX line in, but you could just tighten/ replace O-ring (I think they're O-ringed)
just another place to look... good luck
Robb
Robb, they are O ringed but it doesn't sound like 1a2a3a's problem.
Oh, no no. Just step back and take a break. Get the PSD running and you'll be a lot happier with it then a 351. Of course, I should just mind my own business!! LOL
hey men myn is doing the same thing, always has a small oil puddle in the center front, had coolient in it to day, found out its my oil cooler leaking and oil is running down front crossmimber on to frount end and makes it look like its in the center of the truck, look at the oil cooler on drivers side good luck man
mine looks like its leaking on the passenger side somewhere. the driver side of the motor is pretty much dry buy the passenger side is soaked. and yes i do have a crap load of oil dripping off the crossmember but the oil cooler is dry. do you know of anything on the passenger side? the valley on top is completely dry and same with HPOP lines and plugs.
It might be coming out of where the oil dipstick goes thru the oil pan. That's always a common leak area.
yeah thats true, 10 cent fix from parts store, just take the dipstick tude out and with you and you can get an o ring that will work, it leaks just enough you look past it
