1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 f 250 headlights go out when I hit the low beam switch!
Old 12-02-2010, 10:00 AM
crisnbecky's Avatar
crisnbecky
crisnbecky is offline
I have a 2000 f250 when I go from high beam to low beam the headlights go out. If I hit it again it will come back on. It is a intermittent problem. please help.
Old 12-02-2010, 10:41 AM
A H DEVELOPMENT's Avatar
A H DEVELOPMENT
A H DEVELOPMENT is offline
Welcome to FTE,crisnbecky!
Maybe a short in an old(2000) switch?
Old 12-02-2010, 04:25 PM
crisnbecky's Avatar
crisnbecky
is that the multi switch??
Old 12-03-2010, 01:45 AM
JockD's Avatar
JockD
JockD is offline
Do you have Daytime Running Lights? The wiring is different if they are installed.
Old 12-03-2010, 01:47 AM
orng1's Avatar
orng1
orng1 is offline
Have you checked the bulb, could be that simple.
Old 12-03-2010, 07:19 AM
crisnbecky's Avatar
crisnbecky
I do not believe it has daytime running lights. If it was the bulb then why would both headlights go out??
Old 12-03-2010, 07:36 AM
DavidB's Avatar
DavidB
DavidB is offline
Multifunction Switch
Check the connections. If all good, replace the switch.
Old 12-03-2010, 11:06 AM
BCHauler's Avatar
BCHauler
BCHauler is offline
Just to clarify, when you say "when I hit it again, they come back on" do you mean when you put the switch back to high beams? ie. high beams work but low beams don't?
As ridiculous as it sounds, both bulbs can fail at the same time. I tore my van apart on a trip one time when both low beams stopped working. After hours of hunting for shorts, testing switches etc, I changed the bulbs and low and behold, I had low beams again.
Old 12-03-2010, 12:23 PM
thomabb's Avatar
thomabb
thomabb is offline
I just replaced my multifunction switch for the same reason. I had 12v to the switch but 1-2v out. If I worked the switch a couple times I got 12v out.
I cracked open the old switch and it was nasty inside. They are apparently not sealed well. Lots of dust and grime in there.
OEM ~$150 out the door.
Old 12-04-2010, 09:10 AM
AB1946's Avatar
AB1946
AB1946 is offline
I bought a new to me 2000 f350 that didn't have any high beams, and I thought the switch was bad. This fall I hooked up the snow plow, and the high beams work on the plow with the switch so the switch works, and maybe it's just the bulbs.
Bishop1986
1997 - 2003 F150
09-20-2016 08:03 AM
Lesalvato616
02-17-2015 02:04 PM
4INer
02-27-2014 07:27 AM
aircropsinc
12-23-2012 09:03 PM
Rods 1977
11-18-2012 10:43 PM
Quick Reply: 2000 f 250 headlights go out when I hit the low beam switch!
