no start after battery replacement
Old 11-17-2010, 09:29 PM
autoxtech's Avatar
autoxtech
autoxtech is offline
I was wondering why when the battery gets low the truck will not start? It sound like the engine is turning over fast enough but the engine just will not fire, after changing battery work fine, reinstalled some older battery from another truck of which start fine , it will not start this truck, Is there a way to reset pcm after battery install.
Old 11-17-2010, 09:36 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
In order to "reset" the PCM i believe holding the battery cables together for a timeperiod will do it, but I would almost venture to say you have other issues?
Old 11-17-2010, 10:00 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
The Powertrain Control Module (PCM) MUST have a minimum of 10.5 volts applied to it to "fire" the Injector Driver Module (IDM), and thus trigger the fuel injectors.
The starter motor, combined with the current draw to the Glow Plugs, can drag marginal batteries to below this threshold voltage, and thus a "no-start".
"Sounding like" the engine is turning over fast enough is not a good indicator at all.
Good batteries are of primary importance to Powerstroke engines.
Pop
erik_bishop
1999 to 2016 Super Duty
04-04-2024 11:51 AM
SleeprLegend
10-25-2014 07:41 AM
Ultraboy
12-16-2013 09:16 AM
Gotanoldtruck
10-26-2013 12:16 PM
69jwatson
17
02-02-2013 02:55 PM
Quick Reply: no start after battery replacement
