'56 and '59 F100 frame swap
Received 4,132 Likes
on
This subject came up not too long ago and there was a picture posted of a 57-60 vintage and there is a difference in the front cross members and definatly the cab mounts. You would be better off looking for a 53-56 frame as mentioned, where the only difference is the length of the rear leaf springs on the 55-56 model years which shouldn't creat any problems for you. With all the parts trucks out there you should be able to come up with the proper frame that would eliminate the headaches you'll run into with the later frames.
johnmel59
04-08-2014 05:03 PM
uglytruck59
06-24-2011 07:56 PM
