Short bed and panel frame interchange
Old Jun 23, 2011 | 06:25 PM
uglytruck59's Avatar
uglytruck59
I wanted to see if a frame from a short bed 1959 f100 was a direct swap for a same year panel truck frame. I recently saw a panel body for sale that did not have a title. I have a 59 swb truck that is rusty, but has a title. If the frames are interchangeable, is the glove box door the only other thing I would need to make the swap legit? Do the f100s and panel carry the same type of vin numbers? Thanks for the help.
Old Jun 23, 2011 | 08:47 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Ugly,the F100-based panel came with the 110" wheelbase,meaning it was a shortbed.That info is according to a Salesman's Quick Reference Chart that I have.
The Body Type code for a Custom Panel Delivery(110" Wheelbase) - C82B
The Body Type code for a Standard Panel Delivery(110" Wheelbase) - C82A
Steve
Old Jun 23, 2011 | 09:45 PM
uglytruck59
Thanks for the info. One more question, do the panels carry the same F10 prefix to the VIN # as the F100 trucks?
Old Jun 23, 2011 | 11:16 PM
ibuzzard's Avatar
ibuzzard
I don't know for sure,but I'd guess yes, as it is based on the F100.
Old Jun 24, 2011 | 06:26 AM
uglytruck59
Thanks again. I was assuming they would also.
Old Jun 24, 2011 | 08:16 AM
56panelford's Avatar
56panelford
There is a short extension added to the rear of the frame on the panels. On my vin tags there is a difference to the trim code #'s but body #'s are the same.
Old Jun 24, 2011 | 08:36 AM
ibuzzard's Avatar
ibuzzard
56,you may be right, but keep in mind that his is a 59,there are differences.I got the codes from a truck salesmans' quick reference slide-type chart for 1959 models.They didn't say anything about an extension, possibly because by the time of the 57-60 trucks, there were both 110" and 118" wheelbases.That chart shows the panels, in both standard and custom cab configuration, as being on the shorter wheelbase,no mention of any extension.Literature can and does have mistakes/misprints, though.
Steve
Old Jun 24, 2011 | 07:56 PM
56panelford
Yeah, I'm not up on the 57-60's series but thought that the frames would likely be the same. The extension I was refering to are just short pieces of C- channel that fits inside the frame rails. Both my pickup and panel have the 110" wheel base.
70FE250
May 8, 2016 07:41 PM
ctorres
Feb 18, 2016 04:42 PM
Schuyles
Dec 31, 2015 03:32 PM
hoss73ford
Aug 30, 2015 08:02 PM
birdman1
44
Sep 8, 2007 09:11 PM
