Replace Duraspark with MSD-6AL
Old 04-21-2017, 11:56 AM
BossFan's Avatar
BossFan
BossFan is offline
My 1978 F250 has a 1984 351W and the Duraspark electronic ignition and stock distributor. I have a MSD 6AL that is just sitting on the shelf. Is this a straightforward swap? Do I need a different coil?
Thanks!
Old 04-21-2017, 05:08 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,717 Likes on 1,388 Posts
There are several ways to do it. You can keep everything you have, and let the original coil wire trigger the MSD box. You will keep your dist, duraspark II box too. Instead of the duraspark box triggering the coil, it will trigger the msd box. You can reuse your stock coil.
The other way is to buy one of their harnesses, and let the Ford duraspark distributor trigger the msd box directly without the ford duraspark II module.
The another way is to buy a MSD distributor for your Ford application, and install it and let it trigger the msd box.
Check their website, they have very good instructions there you can download.
Blue and White
11-06-2011 02:17 PM
crescentwrencher
05-14-2008 08:38 PM
cjbronco
16
10-12-2005 03:13 PM
little_mule
Electrical Systems/Wiring
09-12-2005 01:14 PM
dhag911
08-07-2004 12:57 PM
Quick Reply: Replace Duraspark with MSD-6AL
