Now what
Now what
Yesterday I was driving my 2001 7.3 excursion down the road and I noticed the temp guage was pinned at the top. So i pulled over and shut it off. Then I checked my oil and it was like wayyyyyy over the high line. Also my coolant was really low but showed no signs of leaks. I called ford and they said to bring it in right away. I brought it in and they looked at it today and said the motors toast
any ideas on how this happened? I guess the coolant got into the oil????
thanks
thanks
I don't think it could be the cooler, if the cooler was bad you would have had oil in the coolant not coolant in the oil ( I think) but it could be a cracked head or blown head gasket.
A new long block would fix that but I would rather see the heads come off for diagnostics. Either way if the dealership does the work it's not going to be cheap. new OEM long blocks can be had for ~4700 with a good core ( which you might not have)
is a motor swap something you think you could do yourself?
Yes he would have oil in the coolant (is there signs of oil in the degas bottle?) but the coolant would have got in the oil after he shut down the engine do to the drop in oil pressure and the increese in coolant pressure from overheating.
so if they pressurize the cooling system with the engine OFF and the cooler is bad......bingo, coolant out the drain plug in the pan. It's a cheap check to pull the cooler off and inspect the o rings.
Ford said I needed a new 2011 truck when all I needed were new batteries. Seriously. This was last week and they actually said I would be better off trading in my truck due to the miles and buy something new with a warranty. I asked for replacement batteries since mine were under warranty and they refused because I didn't have my original purchase receipt. I did have the receipt from last summer when they were replaced under warranty and it had been less than 3 years still so they should have been replaced again. They showed the original purchase in their computer, with the date but still refused to honor the warranty because I didn't have the original receipt in my hand. (Robert Horne Ford in Apache Junction AZ).
Of course I had the original receipt at home so I fetched it and went to another dealership and they promptly replaced both my batteries. (Berge Ford in Mesa AZ).
So, I would not trust the dealership with your cash. If you are mechanically skilled and have the will, these guys will get you back on the road for a lot less money than the dealer will. I third the 'check the oil cooler' suggestion.
Sorry for the rant but getting raped by the dealership is becoming more and more common and I hate to see it happen. I hope the dealer is wrong and your engine is not toast.
Subscribing.
Subscribing.
Here is a thread to read very informative. Hope this helps, not trying to scare you in any way. Just hopping your problem doesn't turn out to be what his was. If I were you I would get the truck home and start trouble shooting it my self along with the help of FTE. Alot of these guys are very helpful.
https://www.ford-trucks.com/forums/9...y-mongo75.html
Evening everyone, I have more to add to quader's issue. He's my son
01X 142K bought in March 119K. New trani,steering box,tires,and basically a clean Limited
I do the maintenance on the truck,Rotella 15-40 and all the basics every 5k ,The expansion tank looked funny on Sunday .kinda like a snapple at the bottom but on the surface . Added a little anti-freeze.
Drove to the Jersey shore. On the way home I looked down and the high temp light was on . looked at the gauge and yup (Pinned). I pulled over an shut it off . Opened the hood and the tank was empty . I looked all under and around the truck and nothing was wet ??? I sat there for 25 minutes and started the truck . Temp mid range . Started to drive down the shoulder to get to a gas station and thought !!! Oil . Shut it off and pulled the dip stick . 1 1/2 over full . UH OH !! That's where it went.
Towed it to a Ford Dealer and I'm being told "Based on their test " It's not the " O " rings . Something internal let go . I don't believe them . I called a Diesel shop (large equipment) and ran it by the guy . I buy my Stanadyne fuel additive from him . He said oil cooler .
I'm gonna tow it to my house Monday and take the cooler off. It broke down 2 weeks ago to the day . Alt went . Towed it home . Charged the batteries and checked the output and yup Alts bad . I fix pretty much everything on it but this one threw me a curve .
Your help is greatly appreciated .
Here's the thread Cody did. Good read. https://www.ford-trucks.com/forums/9...e-of-year.html
Ahh you beat me to it
