Modding a factory gauge cluster to fit Autometer gauges
Old 10-28-2010, 01:27 PM
TheKirbyMan's Avatar
TheKirbyMan
TheKirbyMan is offline
Question Modding a factory gauge cluster to fit Autometer gauges
I eventually plan to get a new complete set of Autometer gauges for my truck (see link below for pics). I don't want to cut up the dash to mount them though. I had an idea to modify a factory gauge cluster body to fit the new gauges. I currently plan on having a tach and speedo (3 3/8" diameter) and four smaller gauges for volts, temp, oil and fuel level (2 1/16" diameter). The final design would be such that I could remove the gauges as a group, have the clear plastic cover in place, and maybe even have the trip odometer reset button be able to press the calibration button on the new speedo.
Right now I'm just trying to get some ideas rolling on how I'd pull this off. If there's some way I could wire the gauges through the factory circuit film, that'd be even better. I'm just not sure if the contacts on the film for, say, the water temp gauge, are for gauge power and the sending unit. If going through the circuit film would be too much trouble, I could just put something together to bypass it, or somehow keep the film in place but wire the gauges by hand.
Auto Meter ES Series Gauges - JEGS
Old 10-28-2010, 05:35 PM
00Boss's Avatar
00Boss
00Boss is offline
I cant wait for updates. Id love to do this with mine
Old 10-28-2010, 06:17 PM
alhauger's Avatar
alhauger
alhauger is offline
In the intrest of saving your cluster, you could just make a flat panel the size and shape of the front of the cluster in which to mount your new gauges. Then you could just bolt on the clear lens from the original cluster and bolt in the panel and wire it up. Your cluster would remain whole, except for using the lens and you could design the look of it however you want. Seems like just a piece of 3/8" MDF would suffice.
Old 10-28-2010, 08:17 PM
TheKirbyMan
That's a great idea!
I had an idea for how I'd wire it too. I'd get my gauges mounted; I would then get some short bolts and mount them onto the panel in such a way that I can use them for power distribution (yet they wouldn't be visible from the front of the panel).
For example, I would have one main power lead from my addon fuse panel going to the bolt, and all the gauges' power wires would connect to that bolt with eyelet connectors. Same with the power for the lights and ground connections. I would find some sort of connector for the sending unit leads though, since you can't combine them into one connection.
It may be a year at the least before I can get the gauges (they cost money, I have little), but as I can afford it, I could start putting the panel together as a project and use a spare 2-1/16" voltmeter I have as a template for the smaller holes.
I will still need to address the various indicator lamps on the factory cluster though. Any ideas?
I've seen custom gauge panels on here, but none of them really were what I want. I'd like to retain my AC vents and an overall factory appearance, while still having modern gauges.
Old 10-29-2010, 02:15 AM
panman65's Avatar
panman65
panman65 is offline
this one is a sweet set up not mine its what blue80 did to his
Old 10-29-2010, 06:43 AM
ozstang65's Avatar
ozstang65
ozstang65 is offline
The warning lights are in their original location, however I've soldered wires to the back as they don't use the original circuit board. I completely rewired the truck so I couldn't suggest how to incorporate them into the original wiring.
Old 10-29-2010, 07:46 AM
masseysbronco's Avatar
masseysbronco
masseysbronco is offline
Don't the factory cruise control modules take the input from a speedometer cable and convert it to an electrical signal? I wonder why you couldn't use one just for this purpose, and use that electrical signal to feed an aftermarket speedometer. The 8.8 axles and the older BW1356 transfer cases also have the ability to use electronic vehicle speed sensors (VSS) which feeds the speedometer on the newer clusters. If you found an easy way to use another speedometer you could modify a junkyard cluster anyway you wanted, and then hook it to the necessary wires in the factory harness with wire taps.
Old 10-31-2010, 05:42 PM
00Boss's Avatar
00Boss
00Boss is offline
I love the way yours turned out. Looks awesome
Old 01-08-2012, 11:20 PM
paintinpevs91's Avatar
paintinpevs91
paintinpevs91 is offline
Did you do this yourself?
If so how?
I'd love to do something like this on mine.
Old 03-25-2013, 07:40 AM
Dejayp's Avatar
Dejayp
Dejayp is offline
That is exactly how I want my interior to look!!!! Did you make any plans up for the center console? And what year/model car are the seats from? Awesome effort on the truck mate
Old 03-25-2013, 11:28 AM
f100beatertruck's Avatar
f100beatertruck
f100beatertruck is offline
There's an inline adapter that goes into the trans/transfer case that gives you the electronic adapter. They even used it with the E4OD from 89-91. It generates 8 pulses per rev and should work with any trans/TCase offered or even swapped.
F-series from 84-91, Vehicle/transmission speed sensor.
Standard motor parts - SC46
Also, Motorcraft DY382
Also, E3AF9E731, E3AF9E731AB, E3AZ9E731A, E6DF9E731CA, E6DZ9E731C, E9TA9E731AA, E9TZ9E731A, F3AF9E731AB, F3AZ9E731A
Old 03-25-2013, 04:17 PM
TheKirbyMan
This topic is over a year old. lol
Old 03-25-2013, 05:30 PM
xjfever's Avatar
xjfever
xjfever is offline
http://cgi.ebay.com/ebaymotors/80-86-Ford-Pickup-Black-Dash-Carrier-Panel-w-AM-Phantom-Mechanical-Guages-/271020760602?pt=Vintage_Car_Truck_Parts_Accessories&fits=Make%3AFord%7CModel%3AF-150&hash=item3f1a189e1a
Lots of these on e-bay, but they are not cheap.
Old 03-25-2013, 08:54 PM
Ford F834's Avatar
Ford F834
Ford F834 is offline
Well... did you ever modify your dash? Or did you just stick with factory guages or other aftermarket guage locations?
Old 03-25-2013, 09:04 PM
00Boss's Avatar
00Boss
00Boss is offline
Iv been tossin the idea of doin a cluster that looks like a kenworth. Not quite sure how to make it look right.
JWA
28
02-01-2020 03:26 PM
cyclone-429
36
01-28-2017 09:18 AM
Gicknordon
76
11-08-2016 09:36 PM
93nighthawk
Aerostar
39
09-23-2015 08:55 PM
KingBluey
05-17-2011 11:16 PM
Quick Reply: Modding a factory gauge cluster to fit Autometer gauges
