1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What is the size of Torx bit for the front seat bolts
Old 10-28-2010, 07:06 AM
rdct's Avatar
rdct
rdct is offline
T55 is sloppy. T57 doesn't fit. Is there a T56?
Seat has started creaking on the front mounts - I think cuz of 5 Star Mike's tuner....
Old 10-28-2010, 12:51 PM
BCHauler's Avatar
BCHauler
BCHauler is offline
I just installed a centre console seat on my 01 and it took a T55.
Old 10-28-2010, 01:05 PM
bunklash's Avatar
bunklash
bunklash is offline
I've read somewhere that there is actually a different set of Torx called Torx Plus, or something like that. I regularly remove my rear seat, but have made do with the T55 since the Torx Plus are so hard to find, especially in single bits.
Anybody locate a good source for single T-P bits?
Old 10-28-2010, 02:49 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
I used T55 as well. Torx-Plus is used in the bed bolts too, which is probably why I broke two Snap-On bits trying to remove them. I'd also like a source for T-P bits.
Old 10-28-2010, 04:41 PM
2002 F350V10's Avatar
2002 F350V10
2002 F350V10 is offline
I just removed a seat from a superduty last week. I misplaced the torx bit, so I ended up at sears and bought a large 4 bit torx set in 1/2 inch drive for about $40 and then used a 1/2 inch air impact after spraying the threads from underneath. Whatever size it was, it was bigger than the bed bolts.
Old 10-28-2010, 06:56 PM
DavidB's Avatar
DavidB
DavidB is offline
Old 10-29-2010, 05:20 AM
rdct's Avatar
rdct
rdct is offline
Thanks for the replies. A guy in the local auto parts place was trying to convince me that I needed a metric Torx. (?) Never heard of such a thing - but alos never heard of a T-Special.
DaveB - great find. I couldn't find a price worth buying after a short search. Thanks for that. Too bad shipping costs more than the damn bit
Old 10-29-2010, 08:22 AM
DavidB's Avatar
DavidB
DavidB is offline
Shipping
Yea, shipping always kills me. If you can use them, take a look at some of the Torx plus sets on the same site. Sort of takes some of the sting out of the shipping on a larger order. Also some other good tools there.
Old 10-29-2010, 05:04 PM
bunklash's Avatar
bunklash
bunklash is offline
If the shipping wasn't so high, I'd order the one bit, but so far the regular T55 has worked well enough.
Ordering a set would be nice, but the only one they offer with the T55 in it is $110!!! Dadgumit!!
Old 10-29-2010, 06:42 PM
cartmanea's Avatar
cartmanea
I've removed all my seats twice now with the regular T-55 and it works fine. The bed bolts on the other hand... I'll buy a few Torx-Plus bits that size before I attempt those again.
Old 11-23-2011, 04:13 PM
soffty's Avatar
soffty
soffty is offline
torx plus
The Ford truck seat and seat belts are installed using a TP55 Torx PLUS, which is a new modification (improvement) over the regular torx. You can buy a OTC socket 3/8 drive on eBay for $14 or the 11 piece set for $35. I remove these bolts almost every week and Torx PLUS are better than torx but I still think it is just a way to make money designing new tools. The torx T55 will work fine if you don't have to use it often.
Old 01-09-2017, 04:47 PM
Ken in CA's Avatar
Ken in CA
Ken in CA is offline
Large Torx bits source
Harbor Freight
$11.99
T20, T25, T27, T30, T40, T45, T50, T55, T60 3/8" bits
Old 01-09-2017, 06:23 PM
ligito's Avatar
ligito
ligito is offline
Put a piece of masking tape on the Torx bit, if it's a sloppy fit.
Old 01-10-2017, 10:32 PM
bunklash's Avatar
bunklash
bunklash is offline
dieseldrive
2017+ Super Duty
21
12-07-2017 10:44 AM
The rock99
Ford Truck Parts for Sale
10-08-2017 12:04 PM
BleackBeast
09-22-2017 11:45 PM
_Trekker
03-04-2017 10:48 AM
Markyboy
06-30-2016 09:28 AM
Quick Reply: What is the size of Torx bit for the front seat bolts
