As a novice mechanic and professional idiot I accidentally drained my transmission fluid while meaning to drain my oil for a simple oil change.
I added more transmission fluid though the dipstick hole, but I still get minor "slippage" in my transmission. Especially when putting the gear in reverse.
Also, the oddest thing is an electrical crackling noise from the transmission drain pan after the truck is shut off.
Should I just add more fluids or bring it in and get the transmission fluid and filters done professionally?
Welcome to the forum. I'm by no means an expert, but my first question would be what kind of fluid did you put in it?
Also, tell us what year, model, engine, etc. Somebody will be along to help you.
Automatic transmissions should be checked when warm and running. Cycle through all gears and reverse, then put it in park and check with the engine running. On my '03 automatic it reads at the top of the hot range when cold and not running, so that's not an accurate way to check it.
Reading with the vehicle off is not consistent though, different vehicles will drain back to the pan different amounts. The proper way of checking is engine running and warm in park. Check the level the correct way, the sound you're hearing could be due to the fluid being low.
My book says use mercon ATF for 4 speed and mercon sp for 5 speed. Not sure what I have. Probably 5 speed. Guys at advanced auto told me that other fluid was fine. Did I screw up again?
Is your book for an '02? If you have the 4-speed automatic (the only automatic) I'm pretty sure its Mercon V. If you have a manual it's different. Don't listed to the idiots at the auto parts store, most don't know their @$$ from a hole in the ground.
Should of guessed they were wrong. Also am changing my power steering pump and realized it needs mercon trans fluid. Looks like they just gave me generic (clear colored) steering fluid. Glad I caught that.
Should I drain the DEX III and refill with mercon?
