Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
intake gasket replacement questions
Old 10-15-2010, 01:57 PM
flaredfx4's Avatar
flaredfx4
flaredfx4 is offline
I'm getting ready to replace the upper and lower intake gaskets on my 2001 3.0L due to a suspected vacuum leak and had a few questions. What other sensors or parts should also be changed when everything is off? At 135,000mi all that has been done that i'm sure of is a couple front coils, and the pcv rubber line. I do have a new coils in the garage so maybe I'll change the back ones. Any special instructions or tips for the gaskets? I didn't find any write-ups when I searched. Thanks
Old 10-16-2010, 07:43 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
It's fairly easy to do. I would replace the spark plugs in the back since that requires removing the upper half of the intake manifold too. If you have a good phone or digital camera take pictures so that you get everything back in the right place. It only takes about 2 hours (or less) to do. I got the gasket set at AZ for $8.
Old 10-16-2010, 08:21 AM
flaredfx4's Avatar
flaredfx4
Sounds good, i'll tackle it on monday. Are the oem MC plugs what people usually go with, or is there a better option? I noticed some are replacing the ect sensor when the intake is off, is that necessary?
Old 10-29-2010, 02:28 AM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
heres a great how to.I like Motorcraft or Autolite plugs
https://www.ford-trucks.com/forums/4...ark-plugs.html
DrMario
1997-2006 Expedition & Navigator
08-04-2017 10:30 AM
bjarnold1
05-19-2017 12:11 AM
NotSoSporty98
02-21-2017 03:56 PM
Nitro901
01-06-2017 11:35 AM
cougar73
3.8 & 4.2L V6
10-06-2008 10:00 AM
Quick Reply: intake gasket replacement questions
