Air Down with the ARB E-Z Deflator
Seattle, WA — ARB 4×4 Accessories, Australian based four-wheel parts manufacturer, has just added a rapid tire deflation tool to their extensive line of premium recovery gear.
The unique patented design of the ARB E-Z Deflator allows the valve core to be removed to deflate the tire at an increased speed. An integrated sliding valve provides an accurate reading of the tire pressure while deflation is in process ensuring the desired psi is achieved.
This quality Bronze Bourbon Tube gauge design ensures accuracy is not affected by changes in temperature, humidity or altitude. Made from corrosion resistant brass and stainless steel, this tool has been geared for precision movement. The gauge is covered with a protective rubber guard for maximum grip and features an easy to read dial with one psi increments from 4 to 60 psi.
Packaged in a canvas pouch styled to match the new ARB Off-Road Accessory bags, the ARB E-Z Deflator is the perfect addition to your recovery kit.
Along with convenient ARB E-Z Deflator, ARB offers a wide variety of quality recovery gear including ARB snatch straps, snatch blocks, winch cable dampers, shackles, drag chains and portable compressors to suit all of your recovery needs.
About ARB
ARB Corporation Limited is Australia’s largest and industry leading manufacturer and distributor of quality, 4WD vehicle accessories, with distribution outlets in 120 countries worldwide. The company manufactures and stocks the world’s most respected and sought after brands including ARB Air Locker locking differentials, ARB Bull Bars, Old Man Emu (OME) shocks and suspension, IPF high performance lighting, and Safari snorkel systems, to name a few. ARB USA is the North, South & Central American headquarters and distributor of ARB accessories.
