Fab Fours Launches Utilitarian Adjustable Rack System
New rack system looks great and adds a ton of utility to any pickup.
Adding Storage
One thing truck owners can never get enough of is utility. After all, it's the reason most buy a truck in the first place. Thankfully, the aftermarket has plenty of goodies that can add even more utility to a truck, including extra space to store various types of gear. One of the latest, and most interesting, is Far Fours' new Adjustable Rack System (ARS).
Photos: Fab Fours
Beefy Construction
Fab Fours' ARS is designed to fit any truck and is constructed from beefy 11 gauge U.S. steel. It weighs in at a hefty 200 pounds, which means that it's capable of carrying a significant amount of weight as well - up to 700 pounds of static weight, and 300 pounds of dynamic weight.
Photos: Fab Fours
>>Join the conversation about Fab Fours' Adjustable Rack System right here in the Ford Trucks Forum!
Various Sizes
Finished in a two-stage matte black power coat with epoxy primer, the rack will also hold up to the elements and look great for years to come. In terms of size, the ARS is adjustable to provide a height of 19 inches, widths ranging from 55-64 inches, and a depth of between 60-98 inches.
Photos: Fab Fours
Ready to Mount
The ARS is also designed with a number of tie-down points and mounting points so all sorts of accessories can be added as well, including things like off-road LED lighting, a tent, and many more. The only real limit here is your imagination.
Photos: Fab Fours
Built in Steps
Another great thing about Fab Fours' ARS is that it's designed to double as a sturdy step. There are a grand total of four step locations that provide easy access to the roof, which means that you won't need a ladder or have to climb into the bed to reach things stored up there.
Photos: Fab Fours
Broad Applications
The ARS can be installed via bolt-on or hook-secure mounts rather easily, though you'll probably want some help from a friend to lift the heavy bits in the bed. The innovative adjustable rack system retails for $1,760 and will reportedly fit any truck, making it a truly appealing offering for anyone looking to expand upon their pickup's utility.
Photos: Fab Fours
For help with service of your truck, check out the how to section of Ford-Trucks.com
