C6 4X4 transmission W/NP205 T-case
on
Category: Drivetrain
Price: $950
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '06+ Civic/CSX, Prelude, Fit
Item Condition: CA
It was professionally rebuilt about five-six years ago for a 1986 Ford F250 with a 6.9 diesel. Shortly after the rebuild the engine died and the truck sat for several years. I pulled the drivetrain and took the tranny to the shop that did the rebuild/installation and had them disassemble and inspect it, (it was found to be in excellent condition with no work needed) then reassemble it in a different housing to fit the 460 engine our chapter was building for our project truck. They upgraded it along the way with a new 2000 RPM stall converter, Kevlar 2nd gear band, high pressure billet servo and shift kit, to the tune of $835 dollars. It has not been run since the build, not even had fluid put in it yet.
We then came up with an NP205 T-case and adapter which is bolted to the tranny. The mud truck project died with its owner and we are parting out the remains. Asking $950 for the complete tranny/T-case package. Thanks for looking.
on
The transmissions were all basically the same. The main difference is the bolt pattern to the block and on a 4X4 the tailshaft and housing length. This tranny has the shorter shaft and housing as you can see from the pics, it's about 6 inches long as opposed to the longer one which is about 9 inches and moves the transfer case a little further back.
C6 w/NP205 Tcase
Goodmorning, My name is Aaron Blade and I see that you have a tranny & tcase for sale. My 79 Bronco is in need of both before it snows as I use the truck for plowing. I live in Greer, AZ. 85927. Would you be willing to ship (at my expence) and if so, what would the total cost be? (928) 735 - 7064. Thanks!
on
The transfer case has been sold separately, the transmission is still available for $750 plus shipping. I don't know how much shipping would cost, but I would estimate around $150 from what I've heard.
twinzilla
Ford Truck Parts for Sale
02-09-2018 06:13 AM
CAW-razy Ideas
11-16-2017 11:06 AM
Austin111
09-18-2017 10:09 AM
Kyle Wood
10-19-2016 11:28 PM
