1967 F-100 project
Old Aug 30, 2009 | 10:21 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
1967 F-100 project
After a ten year wait, I"ve finally started on the 67. Started on the tear down this weekend, here are some pics.
The before pics.
Old Aug 30, 2009 | 10:22 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Getting the front sheet metal off...
Old Aug 30, 2009 | 10:24 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Here are a few interior pics. I'm hoping to swap a later model cab, but if not, the floor boards and rocker panels will need a little work.
Old Aug 31, 2009 | 05:27 AM
jowilker's Avatar
jowilker
MUST HAVE: Large assortment of zip lock bags, Sharpie, & LABEL, LABEL, LABEL!
John
Old Sep 3, 2009 | 08:22 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Got the motor out of her last night..
Old Sep 8, 2009 | 07:58 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Cab is all stripped out, ready to lift off. It seems to take forever to get everything out of there! BTW, if anyone could use about 8 gallons of turpentine, I think that is what is left in the gas tank after ten years!
Old Sep 14, 2009 | 10:47 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Body is now off, thanks to my brother-in-law and his tractor. Beats manual labor any day! Cab will probably be replaced, we'll see about the bed.
Old Sep 21, 2009 | 10:19 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Well, it's official: I'm now the owner of FOUR Ford pickups! At least temporarily. I picked this up this 68 from one of the members of the Nebraska Chapter who owns a salvage yard. The cab is in excellent shape, only a litte surface rust on the floors. The rockers are clean, and the cab mounts look to be in good shape. Can't use the bed, the floor is shot, but I may cut off some of the cab sides to use as patch panels for my bed. Better those than aftermarket peices.
Old Sep 23, 2009 | 09:28 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Well, just gotta get the engine towers and body mounts off, and she's ready for sandblasting and paint.
Old Sep 29, 2009 | 11:23 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Frame is stripped and mounted on my homemade rotisserie. Tried to sanblast sunday, but the wind was blowing too damn hard. I'll try again later this week.
Old Jun 1, 2010 | 08:34 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Went and found a 79 to pilfer parts from this weekend. Took the whole front axle, with the disc brakes, the power steering pump and box, and the power brake booster. Also cut out the fuel door, I'll weld this to the side of the bed, once I find a frame tank.
Old Jul 27, 2010 | 08:09 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Thought I'd better update this, the frame is moving right along. Frame has been sandblasted, and all the associated parts cleaned up.
Old Jul 27, 2010 | 08:13 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
After using metal prep on the frame, coated it with POR-15. Note to those thinking of using POR-15, don't use cheap sponge brushes, unless you have a TON of them on hand!
Old Jul 27, 2010 | 08:16 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I'd heard how nasty POR-15 was to get off of the skin, so this is what I wore during application. I borrowed a cool hood from here at work, to keep my head somewhat dry. Basically, it's like a bicycle helmet with a battery powered fan in it, and a hood over it. Worked out really well!
Old Sep 6, 2010 | 08:23 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Leafs back from the powder coater, and reassembled. I'm going to redo the clamps, coat them, and put in some rubber strips. Also got the U-joints replaced in the front axles. It was a mother to get the old ones out. Had to use the blue wrench to heat them up.
