Sliding rear window exchange
Old Yesterday | 10:42 PM
Dano76's Avatar
Dano76
Have an opportunity to swap a rear sliding window from a 77 F-150 into my 79 F-150. It appears to be a direct swap, right? Is there a unique seal for the sliding window vs the solid window? Doesn't appear to be, but just checking. Steele Rubber is my go-to for seals.
Old Yesterday | 11:33 PM
440 sixpack's Avatar
440 sixpack
Same window same gasket. but there are 3 different styles. plain, wide trim and lock strip. none of the repop gaskets fit like the originals did, but you can usually make them work. I use the lock strip version because they seem a little easier to install.
Nitro1168
May 14, 2021 09:36 AM
zigsgt
2004 - 2008 F150
13
Dec 19, 2005 03:03 PM
4xF250
Mar 30, 2002 05:11 PM
