Getting a lifted suspension back to factory ride height
I believe the truck was lifted by the previous owner, and it has oversized tires. I literally don't know anything about how lifts are usually done, never had a lifted truck before and am not a very big fan of modifying the height.
I'd like to return it to the factory height with stock size tires. I measured the distance between the top of the tire and the bottom of the fender, it is 9 inches. Same story on the rear, 9 inches from top of the tire to wheel opening.
The compressed height of the coil spring is about 17 inches. It has rancho shocks all the way around. On the rear, each leaf spring has 5 leaves.
If the truck had taller springs put on, does that mean something was done to the bottom spring perch? Would I have to get new spring perches to make up for the difference in spring height?
When you say compressed height, are you referring to its natural seated position on the truck?
Rear is easy. It'll either have lift blocks or a set of lift springs. Same mounts.
Front axle usually has drop brackets if height is anything over a "level". If so you'll need to source a factory passenger side bracket (for the driver beam pivot) in addition to springs and shocks. Could have extended radius arms, that would require new factory arms and maybe mounts.
17" compressed spring height is on the tall side, probably a 4" lift but I can't say for sure.
I attached some photos of the front and the rear. I measured 17 inches the length of the spring with the vehicle sitting at its natural height. I think it would be a 4 inch lift?
There is a horizontal shock absorber attached to the drag link, I'm guessing that is also part of the lift? I would have to get rid of that as well to get rid of the lift, right?
I forgot to take pictures of the leaf spring hangars, they appear to be factory, I'll add some photos of those as well.
