Alternator Wiring
Old Yesterday | 08:06 PM
Omni43's Avatar
Omni43
Alternator Wiring
I'm putting a new alternator on my 1972 F250. Went to the parts store and was given an alternator that has 4 connections. I'll show you in the first picture. On the second picture is all of the connections on the alternator in the parts store to verify it was good. Now the last picture is the connector that I have in the truck. This doesn't seem right. I see 3 connection points on this alternator harness. Do I need a different alternator or different connectors on the harness?
Any info would be appreciated.
Old Yesterday | 08:16 PM
JimsRebel's Avatar
JimsRebel
Do you have an AMP METER in the instrument cluster?
There's 2 different wiring diagram, depending on charge light or AMP METER.
In both cases, you will need a wire on the field terminal on the alternator.
Do you need the Stator output on the alternator for an electric choke? The auto parts store did test the Stator output, but only you know if you really have a need for it.
Jim
Old Yesterday | 08:21 PM
JimsRebel's Avatar
JimsRebel
If you don't mind me asking, can you still buy a new alternator, or is rebuilt the only thing left. Current price for new or rebuilt?
Old Yesterday | 08:34 PM
JimsRebel's Avatar
JimsRebel
This link has information on the 2 wiring configurations.
https://www.ford-trucks.com/forums/1...l#post21845897
My guess is that you have an AMP METER.
Short answer is you are over thinking it. Connect the Field wire and start it up.
In the over thinking it category, some folks like a extra ground wire, from the alternator ground stud to one of the hold down bolts for the voltage regulator. Extra grounds are always a good thing, especially on old rusty trucks.
Jim
Old Yesterday | 08:56 PM
Omni43's Avatar
Omni43
This is a Chinese rebuild. I looked around for something new, but you know how it goes.
Old Yesterday | 08:57 PM
Omni43's Avatar
Omni43
No amp meter.
Old Yesterday | 08:59 PM
Omni43's Avatar
Omni43
Is the field wire the one that is sticking midway out of the harness?
Old Yesterday | 09:17 PM
JimsRebel's Avatar
JimsRebel
Most likely, how many wires are in the harness that goes to the alternator?
Old Yesterday | 09:24 PM
Omni43's Avatar
Omni43
Forgot to add the rebuilt was 59.00.
Old Yesterday | 09:26 PM
JimsRebel's Avatar
JimsRebel
If you only have 2 wires going to the alternator, the larger one is connected to the output (BAT).
The smaller one would go to the field, (FLD) with the white insulator.
Did the clamp point, shown in your photo, connect to the ground lug in your last alternator installation?
Jim
Omni43's Avatar
Omni43
I would think that all 3 of the wires on my harness are for the alternator.
JimsRebel's Avatar
JimsRebel
Much cheaper than I thought it would be.
Old Yesterday | 09:28 PM
JimsRebel's Avatar
JimsRebel
In your photo, I only see 2 wires.
mustang81
May 8, 2025 08:38 AM
DatBoiED
Dec 17, 2023 09:53 AM
Csnell3732
Large Truck
Jan 19, 2022 09:32 PM
Indio119
Mar 17, 2021 07:20 PM
GaRedneck91
59
Jan 10, 2015 09:40 PM
