Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1962 ford c600
Old Today | 12:59 PM
Shh1966's Avatar
Shh1966
Trailering
1962 ford c600
I’m struggling to find a rubber brake hose to connect the master cylinder cab line to the frame line. It needs to be 5/16 I’d it needs to be flexible hose so the cab can tilt. 3/8 and 3/16 are all i can seem to find. Any ideas or help is appreciated. I’ve found air brake line in that size but totally different fittings and lower psi rating. The fittings on the end of the needed hose ideally are 1/2 x 20 threads inverted flare on both ends
Old Today | 07:25 PM
asavage's Avatar
asavage
FTE Community Team
I'm getting nowhere with this. It took me ages to locate the line in the Illustrations, and I finally found it because I know 2140 is "master cylinder". The MPC shows what sure looks like a three-piece line, with steel on both ends and rubber in the middle:
But the * part of *2352 note says to cut from bulk tubing in Group 2269, which is just a list of bulk tubing:
And 2352 doesn't seem to point to what we're looking for, either: it's all for booster vacuum lines (and their fixing clips):
elkhart75839
Mar 18, 2024 03:06 PM
lomesome1
Jun 13, 2021 06:22 AM
brenjimin
Oct 15, 2013 09:10 AM
f2504x4man
Jul 27, 2013 04:25 PM
PetrozP
1978 - 1996 Big Bronco
May 16, 2004 03:21 AM
