95 5.8 alternator bolt and squealing
Old Jun 14, 2026 | 11:38 AM
Motohowie's Avatar
Motohowie
Hi all. Charging dropped to 11 yesterday, battery light came on. Wiring checked out ok, battery and cables good, suspected voltage regulator but the alternator was original so I replaced it.
First question: it was held on by three bolts, all the same size, but I can’t be certain they’re correct. Online show several sizes and lengths in the kits. All were tough to get out, and one has chewed up threads so I went to Advance, Autozone, O’Reilly’s, and Napa. Nobody had one. Computers show multiple options but none matched. It’s the tip that’s screwed up so tough to verify the thread size using the gauge. I’m driving with the upper and one lower bolt. Anybody know the size and where to buy?
Second question: Now it occasionally squeals for several seconds at startup then goes away. Happens like every other time. Belt looks good, tension seems good, looks to be properly aligned. Battery should be charged back up by now so it shouldn’t be excessive load. Any suggestions?
Thanks for any help.
Old Jun 14, 2026 | 05:16 PM
Soup bean's Avatar
Soup bean
Take one bolt out. Go to the store. Match the threads.
Or, cut the chewed up end off the damaged bolt with a band saw and check the threads
Third option, buy a 7/16-14 x whatever length you need, and try it.
Old Jun 14, 2026 | 11:41 PM
seschenburg's Avatar
seschenburg
You might be able to pick the aluminum from the bolt threads and reuse it. What you're seeing is galling, when dissimilar metals are forced together under great pressure. Kinda like friction welding, but not that hot. The weaker metal (aluminum, in this case) will overheat and flake off, sticking to the harder metal (steel of the bolt). Before reassembly, apply a light coat of oil to the bolt threads, tighten securely but nothing extra, and you'll avoid this problem in the future.
Old Jun 15, 2026 | 07:55 AM
Motohowie's Avatar
Motohowie
Thank you Soup Bean. Had those on my list but hoped someone might say “Mine’s the same. You can delete your muffler bearing and re-use that bolt.”
Old Jun 15, 2026 | 08:00 AM
Motohowie's Avatar
Motohowie
Thanks seschenburg. You’re absolutely right, I can see now that it’s aluminum and the threads are still good.
If anyone else needs this bolt, turns out it’s an M10-1.5 x 85mm, which didn’t show up as an option on any of the parts store systems. It was $2 at a place called Threads for the South here. And now I have a spare thanks to seschenburg..
RTT
37
Sep 11, 2023 01:12 PM
ZombieSlayer
1978 - 1996 Big Bronco
Feb 15, 2014 11:34 PM
BillyBob69
Aug 10, 2007 07:35 PM
RCM
1983 - 2012 Ranger & B-Series
Nov 11, 2006 07:06 AM
myke
1997 - 2003 F150
Mar 16, 2005 06:49 PM
