Charging issue
My vehicle is a '96 2.3L Ranger w/ 185,000 miles. Stock vehicle, meaning there is nothing that needs power.
I have replaced the battery this week after it left me on the side of the road and the parts store said it wasn't holding a charge. The battery was 6yo.
Now, the battery gauge on the dash is registering rather low and the battery light stays on. Once I get into higher rpms the battery gauge jumps up to where it seems was the nomal range, the light goes out and my headlights become brighter.
There was a fair amount of corrosion on the cables and posts of the old battery and I have since cleaned the cables as much as possible with H2SO4 battery cleaner & acid detector. Cables are stock.
My alternator was replaced in '01.
My question to you guys is where to start?
thanks in advance
2. Even though you replaced the alt, in 01 -- Have it tested -- your local auto patts store should be able to test it on the truck.
When you have a bad battery, the alternator is forced to work as hard as possible to try to recharge that battery.. forcing it to run on 100% output all the time.
In other words, your battery burned up the alternator. I've seen it many, many times.
