Sponsored by: Real Truck
Engine swap
Old Today | 10:12 AM
JDAustill's Avatar
JDAustill
3rd Gear
Engine swap
I bought a 2000 F-350 as a project. The V-10 engine was bad, I was aware of that when I bought it. I have come to the realization that I do not want to replace the V-10 as I don't have any confidence in this engine. Does anyone know if the 5.4 V-8 will bolt directly to the existing transmission or will I need a conversion/adaptor? Any and all help is greatly appreciated!!!
I just signed up on this forum under the "FREE" signup. If this forum is as helpful as I've been told I will sign up for a better membership! Thanks in advance!!
Old Today | 10:43 AM
Antonm23's Avatar
Antonm23
The V10 and V8 engines are very similar in architecture and even share many common internal components (like the pistons and connecting rods are the same between both engines). If you "don't have any confidence" in the V10, then you should also not have any confidence in the V8's either.
If you absolutely hate the v10 and must swap a V8 into it,,,then maybe a Chevy LS or an old school Ford Windsor (like a 302 or 351) might be a better option.
Old Today | 11:20 AM
99powerstrokedF250's Avatar
99powerstrokedF250
^^^ This.
The 5.4 is a good engine as long as you take care of it, deal with the cam phasers, and have the issues with the spark plugs dealt with. Same goes for the V10, though with its higher torque it is actually more desirable than the 5.4.
They are VERY similar engines, as pointed out above - they're called 'modular' engines for a reason, the only real differences are the casting lengths, cams, and cranks. Even the castings for the heads/block are made by adding another section to the mold to get the V10.
If you don't like the V10, you won't like the V8, and I agree that a different swap might be what you're after. Depending on the level of tech you want in it, you could go for an LS swap, an old Windsor, or a 460. I don't know if anyone's done it yet, but you may even want to look at a 5.0 Coyote.
Old Today | 11:56 AM
JDAustill's Avatar
JDAustill
3rd Gear
Originally Posted by Antonm23
The V10 and V8 engines are very similar in architecture and even share many common internal components (like the pistons and connecting rods are the same between both engines). If you "don't have and confidence" in the V10, then you should also not have any confidence in the V8's either.
I really like that idea but those are getting very hard to come by. My first choice was the 12 valve Cummins I have sitting in the shop but swapping from gas to diesel is a bit more than I can get to for a while. Just wanting to get it up and running so I can use it til then! Thanks for the input, much appreciated!!
Old Today | 11:58 AM
JDAustill's Avatar
JDAustill
3rd Gear
Thanks for the info!! Gives me more to think about and probably saves wasting effort on a useless project!!
Joefaus15
Jul 22, 2024 09:12 PM
danlee
Nov 23, 2012 07:10 PM
XbigXredX
Nov 10, 2012 11:00 AM
deputyb
Aug 22, 2011 07:28 PM
s1120
Engine Swaps
Aug 19, 2004 04:55 AM
