Sponsored by: Real Truck
Got an A/C issue
Old Jun 11, 2026 | 01:23 PM
Big-1's Avatar
Big-1
Got an A/C issue
Okay. My A/C is working fine, but I cannot get it to stop blowing out the defrost vents up against the windshield. I have 425,000 on the truck and one time before, I disconnected the battery for about 30 minutes and I think the dampers reset and didn't have the issue. My mechanic is moving his shop, and he said that there are vacuum things going on in the dash and he can fix it, but in south Alabama, A/C is very important. Any thoughts?
Thanks in advance.
Old Jun 11, 2026 | 02:17 PM
Pikachu's Avatar
Pikachu
The mode is vacuum controlled and if vacuum is lost, the default discharge is through the defrost ducts. You most likely have either a broken vacuum line or no vacuum due to a blown fuse, bad pump or something along those lines. There's a vacuum pump on the right fender, just forward of the HVAC blower. Put the ignition in the ON position with the engine off. Does the pump run continuously? Does it run at all?
Old Jun 11, 2026 | 02:20 PM
Big-1's Avatar
Big-1
Thank you. Let me check when I can.
Old Jun 11, 2026 | 02:30 PM
Pikachu's Avatar
Pikachu
Also, the fuse for the pump is under the dash; 15A fuse in position 27. There should be +12v to the vacuum pump harness connector on the light blue wire with the pink tracer with the key in the RUN position, and battery ground on the black wire.
Old Jun 11, 2026 | 05:16 PM
Big-1's Avatar
Big-1
You sure it's 27 & not 24?
Old Jun 11, 2026 | 05:40 PM
Pikachu's Avatar
Pikachu
The wiring diagram is showing it as 27. Do you have manual or electronic controls?
Old Jun 11, 2026 | 06:33 PM
Big-1's Avatar
Big-1
I think it's electronic. 2007 King Ranch PSD.
Old Jun 11, 2026 | 06:43 PM
Pikachu's Avatar
Pikachu
I don't think it matters for now, but do you have *****, or are there buttons and a digital readout?
Old Jun 12, 2026 | 07:52 AM
Big-1's Avatar
Big-1
I apologize. I mis-understood what you were asking. My A/C controls are electronic.
BRONC-OH
1997 - 2003 F150
Aug 24, 2017 09:04 AM
pcdocta
43
Mar 19, 2017 04:16 PM
45 ACP
Aug 6, 2011 08:43 PM
minnesotakim
1997 - 2003 F150
17
Sep 28, 2007 07:40 AM
adelyser
Jul 20, 2002 06:54 AM
