carb swapping my efi 5.0
Old Today | 04:14 AM
Tehill's Avatar
Tehill
1st Gear
Thumbs up carb swapping my efi 5.0
I have a 95 f150 xl 5.0 / 5 speed and I've been thinking about converting from efi to carb., when I do this will I have to change the pcm or delete some things...like what is the process.. as far as the mechanical stuff I already know I have to swap the lower intake or get an adapter plate. I'm at some point goin to put a small cam in, and install the GT40 heads and intake. but I know if I keep the factory fuel pump then I'll have to get an adjustable fuel pressure regulator and what not but what will I have to or not have to worry about on the electrical/ ECM part?
Old Today | 05:19 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Tehill
I'm at some point goin to put a small cam in, and install the GT40 heads and intake…what will I have to or not have to worry about on the electrical/ ECM part?
There is no reason to toss the EFI in the trash for a “small cam” and GT40 heads. You would also need to change the ignition system since the EFI computer controls advance.
Old Today | 05:28 AM
Mudsport96's Avatar
Mudsport96
The amount you would spend on carb swapping it, you could get a custom tunable efi computer and be way ahead.
onan302
May 15, 2011 08:05 AM
IowanStraight6
Oct 1, 2009 09:34 AM
RiveraD123
Nov 18, 2004 12:52 PM
Jimmy Dean
Mar 21, 2004 10:11 AM
rayvin_
Nov 5, 2001 06:59 AM
